Bjarne
 - Bjarne
 - 2,155
 - 1
                I think they should do away with the voting bit. Says me, who's number 168 on the list :-D What people need is to find one which can cover the geographical target one wants to listen to. With around 170 receivers online, it's increasingly difficult …
                Thanks John for resolving this! Usually I do have a hinch about what's wrong but this time I was in total darkness. I am very grateful! For those who want to visit the northernmost KiwiSDR, the link is now kongsdr.proxy.kiwisdr.com:8073
                And then I lost contact again. And a few minutes later, back on. What??? NOIP seems to be ok. Internet connection ok all the time. And now it's gone. How to resolve this??
                It was on, and visible on its local network, but not outside. Since for once I didn't have a PC connected to the network, I couldn't restart the server or Beagle. Seems to be ok now.
                Only a brief remote test: Very much better, though I didn't test all zoom levels like Martin did. Will check out both local and remote later today. Bjarne
                It should be noted that I experience the same behaviour (both with audio and less latency) on remote and local connections.
                Yes, selecting Snd and reload seems to have "normal" audio. I missed the "reload" in your first posting.
                Likely the same problems as Martin. Audio sample here: https://www.dropbox.com/s/c1wrj04pzbp53ez/kiwisdr_9480_v1115.mp3?dl=0 Never had this before as I can remember. Surface Pro 3, Chrome. Regards,Bjarne
                You should consider potential noise if the pump is electric. I actually have a rather serious interference problem (though mostly on LF) caused by a water pump fed from a 200-metre long, presumably unscreened, AC power cable. The cable is around 250…
                I set up donation link to my site. It helps. Have a look:kongsdr.ddns.net:8073
                Well whatever happens I need to be there to cut and reinstall power. The PC connected to the same modem as the Kiwi is available, so I don't know what the error is.
                The Kiwi is currently unavailable (I am , rather was, running via Teamviewer). I did run wget and got some response which for obvious reasons I can't rephrase. After cdp and up, after which nothing happened for several minutes, I restarted the serv…
                Ah yes....forgot about the log. It seems to believe that it's running the latest version: Sun Jul 30 14:51:48 2017 0:12:53 0... UPDATE: force update check by adminSun Jul 30 14:51:48 2017 0:12:53 0... UPDATE: checking for updatesSun Jul 30…
                To add to John's comment: It's somewhere like USD28 for two years of hosting at noip with no recurring confirmation request. Bjarne Mjeldearcticdx.blogspot.com
                Thanks James, I have ordered enough to make for all my beverages. That said, for a choke to remove noise there actually has to be (internal) noise, and I'm not sure of the internal/external distribution of my noise sources. Wellbrook made an "…
                All parts except the 40T1417-104 appear to be available. Could there be a substitute/equivalent for the latter? Bjarne Mjeldearcticdx.blogspot.com
                I don't know if this is related to Rob's problem, but I logged into one PC via Teamviewer, which in turn started four sessions of the Kiwi. No problems. I use Teamviewer all the time to control five PCs with Perseus SDRs at two different locations, …
                That was a massive design compared to what I've seen elsewhere, but Jack is/was an RF genius so why not try. I had his active antenna once, and it blew away the Mini-Whip in comparison. Bjarne Mjeldearcticdx.blogspot.com
                Thanks John. I'll have a word with my ISP about that. The strange thing though, was that after I reconnected the PC to the router's network (and assumingly its DUC sent an update), I could access the Kiwi. There are a few variables here I need to so…
                Here's what I did and found. Unconclusive. Log files attached. SERVER RESTART 00:50:49, see kiwisdr_log_210517_0130_1st_server_restart 5 minutes DUC update enabled. I restarted with laptop disconnected from the 4G router. External units could not c…
                I have just changed the DUC update to 5 minutes, and will do a server restart as well, so to replicate the situation and monitor over the next several hours. My setup is a 4G modem/router to which the KiwiSDR and a laptop is connected (via ethernet,…
                Tested again today - with the PC having been disconnected for several hours I tried to connect from remote - no cigar. Connected the PC to the Kiwi's network and a few minutes later I could connect. Bjarne Mjeldearcticdx.blogspot.com
                We'll see when 1.85 comes along! Bjarne Mjeldearcticdx.blogspot.com
                Not my intention to "promote" competing hardware in this forum, but did you consider the RFSpace CloudIQ (as an alternative to Perseus)? Bjarne Mjeldearcticdx.blogspot.com
                I have Gmail in Chrome yes.
                Thanks John. That raises another question: Should the links be there? If I use Edge, the link opens Chrome, but an empty page. Don't know how Firefox, Safari, Opera behave though.
                Back-forward function and A/B VFO get my support. Bjarne Mjeldearcticdx.blogspot.com
                My DUC applet had 5 minutes default update, though I don't think it matters much. Anyway, another thumbs up from the frozen north, I've turned off my local PC and everything seems to be running smoothly. Bjarne Mjeldearcticdx.blogspot.com
                FWIW - after John helped me with my DDNS issue, I decided to buy one year on no-ip. My TP-Link 4G modem/router is highly configurable, so no problems with DDNS once I learned it. Bjarne Mjeldearcticdx.blogspot.com
                Looks like everything is well at my spot, tested from two different locations. Bjarnearcticdx.blogspot.com
