- WA2ZKD
- 16,162
- 13
DIY downconverter
Public Kiwi, WOW
If I am interpreting the sdr.hu data correctly, there are now 366 KiwiSDR available for public access. That's good news. A few "holes" in the coverage however that if filled would be great for TDoA… (more) -
Spur Reduction
This has been discussed here and on net. Here's a simple way to reduce spurious from your shack going back up the feedline and into the antenna. I used a CATV lightning block and mix-31 ferrites.… (more) -
Power issues.
Audio queue depth slowly drops to zero, then resets, causing audio underrun - 8 receiver mode
Grove Project
GPS antenna trick
How many WSPR decoders can be run without affecting performance?
I note that the high-quality shielded Cat cables have the drain wire tack soldered to the metal clip at the plug. Sadly, I have also found that "professional" installers often do not even deal with… (more)
