16,165
14
  • Alternate cooling method
    simple alum. and yes I designed it and made them with a water-cutter. I'll publish the drawing. I have that cardboard baffle there to defleact the air to a more favorable path.
  • rx.linkfanel.net receiver map moving to Leaflet
    Relative to that topic, is there any how-to, guide or documentation anywhere to improving and tuning reception quality on your KiwiSDR?
    I do not think there is anything in one spot. There are many excellent posts here in this forum. Here's a summary of my experiences:
    • Have a reasonably good antenna and keep it away from known RFI sources.
    • Be conscious of things like MW BC overload and apply filters as required
    • Avoid switching PSU, some are quiet but most are not so try to use linear PSU
    • Understand Common Mode Interference, read up on it, applies the easy remedies like use of ferrite core and intermediate grounding on your feedline
    • Watch for spurious using the [SPEC] display on a KiwiSDR client webpage, much noise can be noted by "lumps" of noise or spurs carriers at repeating spacing across a band
    • ID noise spurious by turning things on/off within your dwelling ot near the antenna
    • a partial list...
    G0LUJKA7UG8JNJ
    • a partial list...
    G0LUJKA7UG8JNJ
    • a partial list...
    G0LUJKA7UG8JNJ
    rating receivers is pretty tricky... I see few ranking sites that are indicative of actual usefulness of receivers
    ChrisSmolinski
  • DRM Heard
    Marti DRM loud here in NY this afternoon
    Update: after noting that they were running 9 KHz BW, I pulled the corners of the passband in a tad and got an SNR improvement. China Radio Int'l sits right on the top corner of the 10 KHz passband
    ka9q
  • DRM forces BW [fixed in v1.385]
    adaptive would be great but just allowing the DX label PB value to force the BW rather than DRM forcing it would suffice
  • antenna system tool
    I bought one of the ~$50 NanoVNA and a great little device for testing and aligning coax, filters etc. Here's a shot of my notch filter box using it. NanoVNA-H is the thing to buy, see Google
  • AI WiFi
    all working/routing seems OK...
    After using connmancrl as above I found I need to be sure that the kiwiSDR always found wlan0. I locked the macs for both interfaces in my router. 192.168.1.73 for wlan0 and 192.169.1.173 for eth0. I used a static address in the kiwi network setup to use 192.168.1.73. (73 is site specifc, yours will vary). It works and now I wait for a smarter person than me to tell me a better way :wink:
    192.168.1.173 allows me to get in locally via wire if needed
  • AI WiFi
    I have successfully made my BBAI based kiwiSDR accessible by both eth0 and the AI's internal wlan0. I'll post more details after more testing.
