Bjarne
- Bjarne
- 2,155
- 1
New Kiwi arrived to Arctic Norway
S/n 4340. Quite impressive! As usual I did a sensitivity measurement, and ended up at around -102 dBm on MW and LW (AM, 6 kHz bw, 400 hz 30% modulated signal). The Mayor has promised fiber this summer (it's local elections the coming autumn), so if he keeps his word I will have two Kiwis available, with antennas directed towards North America and towards Asia/Pacific.
Bjarne Mjelde
arcticdx.blogspot.com
(and home of the ArcticSDR) -
KiwiSDR write-up
I run a blog, arcticdx.blogspot.com, and I have this habit of having to write stuff about the receivers I buy and use. I made a new write-up on the KiwiSDR today after 8 months of use. Should anyone be tempted to read it, I will welcome any comments especially on errors I've surely made.Regards, Bjarne -
KiwiSDR write-up
The MS-S7-Web Remote Antenna Switch - In Issue To Be Aware Of
I'm not using the switch with my Kiwi, I ordered it to be able to switch beverages at my KONG DX-ped site. I did a write-up at the time, then today I noticed that I may not be able to use it after all. The issue is noise. Now, the level is very low, so most likely few if any need to consider the noise level for their own setup. More about it here: https://arcticdx.blogspot.no/2017/08/the-ms-s7-web-remote-antenna-switch.htmlBjarne Mjeldearcticdx.blogspot.comkongsdr.ddns.net:8073 -
Linear Power Supplies.
Suggestion - ability to recording sound [fixed in v1.197]
KongSDR with no net connection after power outage [scan tool has been fixed]
New (other) BBG on Ebay (UK)
Bjarne Mjelde
GPS Admin screen
