Bjarne
- Bjarne
- 2,155
- 1
30 min disconnection!?!?
Problem with massive RFI after changing router
Kiwi Noise Floor
@kramcd not necessarily. Good linear PSUs are mostly noise-free. Moreover, many can be adjusted to the roughly 5.2-5.3 VDC ideal voltage. And while not "cheap", a Bel 3A power is only around 50-60 USD from Mouser, excellent value for money in my opinion. Tweakable voltage, and fires up the Kiwi every time without hiccups. -
9955KHz Australia?
sdr.hu is now REALLY closed for non-amateurs
Or so it seems, as I am now longer able to log into the account I have. It appears that someone (Retzler?) has an idea that only amateurs should be allowed to operate web receivers. Nothing wrong with amateurs, but the attitude behind the descision is flawed. It is prejudiced and discriminating. I am strongly tempted to remove my two Kiwis from sdr.hu, since the resource obviously doesn't want me there. And to be fair, right now I am deeply unmotivated to the whole idea of websdr, including my own. -
SDR.hu closed to non-hams?
Antenna recommendation for listening to faraway DRM broadcast inside a city
New Kiwi arrived to Arctic Norway
S/n 4340. Quite impressive! As usual I did a sensitivity measurement, and ended up at around -102 dBm on MW and LW (AM, 6 kHz bw, 400 hz 30% modulated signal). The Mayor has promised fiber this summer (it's local elections the coming autumn), so if he keeps his word I will have two Kiwis available, with antennas directed towards North America and towards Asia/Pacific.
Bjarne Mjelde
arcticdx.blogspot.com
(and home of the ArcticSDR)
