Bjarne
- Bjarne
- 2,151
- 1
30 min disconnection!?!?
Problem with massive RFI after changing router
First of all, make sure it's not the router's power supply. More often than not, a noisy router is not the router itself, but its PSU. If it is the same voltage, and the plug fits, try to power it up… (more) -
Kiwi Noise Floor
9955KHz Australia?
sdr.hu is now REALLY closed for non-amateurs
Or so it seems, as I am now longer able to log into the account I have. It appears that someone (Retzler?) has an idea that only amateurs should be allowed to operate web receivers. Nothing wrong… (more) -
SDR.hu closed to non-hams?
The requirements for the registration process has been the same all the time I think, the difference is that you can't access the site without being registered. When I signed up in 2017, I was… (more) -
Antenna recommendation for listening to faraway DRM broadcast inside a city
I agree that the Alibaba "Megaloop" is probably not worth its money, even at that price level. However, my reference to Bonito was the NTi MegaDipol/MegaLoop, not the Chinese thing. People seem to… (more) -
New Kiwi arrived to Arctic Norway
S/n 4340. Quite impressive! As usual I did a sensitivity measurement, and ended up at around -102 dBm on MW and LW (AM, 6 kHz bw, 400 hz 30% modulated signal). The Mayor has promised fiber this… (more)
