36,739
670
  • Not really interesting.
    As a non-ham you can make up a callsign for registration on sdr.hu
    See the instructions: http://kiwisdr.com/quickstart/index.html#id-sdr_hu
    Lonecrow
  • GPS fixes diminish [fixed in v1.218]
    I see the same. Let's go a few more days and then I think we can call this one solved.
    WA2ZKDPowernumpty
    Possibly fixed in today's v1.218 update. Please give it a try since it takes a while for this problem to manifest itself.
    M0TAZPowernumpty
    M0TAZPowernumpty
  • Software update in progress [not a problem]
    Faster rebuilds coming soon. We are switching compilers from gcc to clang.
    M0TAZ
  • GPS antenna alternatives
    Okay, got it. v1.216 is out with Galileo available on all 12 channels. Another small improvement towards maximizing the number of Kiwis available for TDoA.
    M0TAZPowernumpty
    M0TAZPowernumpty
    Here's an example of all sats being available on all channels on a Kiwi in Iceland. As a bonus QZSS is being received (!) The signal is weak and only 9 degrees above the horizon. It only participated in this one GPS solution before sync was lost. But it was there!
    ChristophPowernumptyM0TAZ
  • TDoA known location markers
    It does this already (if I'm understanding your question correctly -- morning coffee hasn't taken hold yet).
    Before you start the process single-click on a reference station so its information is copied into the field at the lower left of the TDoA control panel. Or optionally type your own reference info, format: lat lon id description. Then the result maps will show that info in a marker in addition to the "most likely" position computed. Also, if you're specifying everything from the URL, you can just list the reference station id to have it pre-selected. Just like the Kiwis to use are specified. See below. Using the Google map ruler we can see the difference in computed to actual location is a bit over 20 km.
    M0TAZ
