- jks
- 36,720
- 670
Galileo down [alert flag added in v1.302]
Since last Thursday/Friday:
https://www.gpsworld.com/galileo-down-over-weekendNOTICE ADVISORY TO GALILEO USERS (NAGU) 2019026 DATE GENERATED (UTC): 2019-07-13 20:15 NAGU TYPE: GENERAL NAGU NUMBER: 2019026 NAGU SUBJECT: SERVICE OUTAGE NAGU REFERENCED TO: 2019025 START DATE EVENT (UTC): 2019-07-12 01:50 END DATE EVENT (UTC): N/A SATELLITE AFFECTED: ALL EVENT DESCRIPTION: UNTIL FURTHER NOTICE, USERS EXPERIENCE A SERVICE OUTAGE. THE SIGNALS ARE NOT TO BE USED.
This may have implications for the Kiwi as the Galileo code does not currently recognize a sat being in an "alarm" state preventing its use in position/timing solutions. For example the alarm state of QZSS sats is correctly detected and an option exists on the GPS tab of the admin page to include alarmed sats or not (Q195 is in alarm as of this writing).
The Galileo code does look for alert pages in the I/NAV messages (page type = 1). But none of these are currently seen. We are looking more closely at the Galileo ICD to see what other bits might be present the code should be checking.
Below is an image where the position solutions differ substantially when Galileo is included in the pool of sats (red markers) versus not (green markers). The green markers are close to the true position.
Christoph's SDRA 2019 TDoA talk from Friedrichshafen is up on YouTube
Alright, I got lucky with some TDoA results and have a new theory. What I thought was the receive site described above is actually the transmitter site (marked "OTHR/CYP2" on the TDoA map below). If you look at that Google map it shows three long element arrays each at roughly 30 degrees to each other (individual array elements are small white dots if you zoom in far enough). This structure is very similar to the JORN arrays seen at three locations in Australia.
To me this makes some sense as this OTHR is very often heard transmitting on multiple frequencies simultaneously. If the beam steering of an individual array has limits then multiple arrays at different angles might be needed to cover the areas of interest.
The Akrotiri site (marked as reference "OTHR/CYP1" on the TDoA map) is full of dozens of Yagis and other TX/RX capable antennas. Probably not the place you want a multi-megawatt ERP service co-located.
SDR.HU Website showing two KiwiSDR receivers
I have updated the documentation at http://kiwisdr.com/quickstart/index.html#id-sdr_hu-dup to be more clear about this problem. -
v1.295: Make audio work on SmartTV browser (WebOS)
Can kiwirecorder select the rx channel it uses or can I detect the rx channel in use?
You get a number of GPS status indications in the output from a /status query of a Kiwi. Instantaneous GPS "lock" isn't one of them, but you can derive it by looking for the "fixes" counter to increment between several queries spaced a few seconds apart. For example curl kiwisdr.jks.com:8073/status produces:
The fixes_{min,hour} counters are for the benefit of TDoA and have a much coarser update rate. Too long to be used as a lock indicator I think. gps_good being >= 4 used to be a necessary-but-not-sufficient condition for lock. But no longer due to Christoph's Kalman filter.status=active offline=no name=0-30 MHz SDR, ZL/KF6VO | Tauranga, New Zealand sdr_hw=KiwiSDR v1.292 ? ? GPS ? ? ANT-SWITCH ? op_email=... bands=0-30000000 users=0 users_max=4 avatar_ctime=1560738755 gps=(-37.631016, 176.172019) gps_good=6 fixes=39613 fixes_min=30 fixes_hour=1792 tdoa_id=ZL/KF6VO tdoa_ch=2 asl=30 loc=Tauranga, New Zealand sw_version=KiwiSDR_v1.292 antenna=Marginal sensitivity uptime=79688 -
Two Public Kiwis on Port 8073? [fixed in v1.294]
So we got this working with the two Kiwis on ports 8073 and 8074 respectively, behind the 4G router and the proxy enabled for both.
Also, the Kiwi network scanner (kiwisdr.com/scan) has been updated to version 1.5 and allows you to specify the port number instead of always using the 8073 default. Handy in the case of a Kiwi with port number other than 8073 with a local ip set by DHCP, and the ip has moved and you don't know what the new one is.
