- jks
- 36,262
- 640
Frequency drift
That brings up an interesting point. The Kiwi GPS software lacks most of the features of commercial equivalents, which were developed over many decades now. One of them is masking out sats (i.e. not using them for position/time solutions) if their elevation angle in the sky is too low. There are various reasons this is a good idea as you might imagine. -
Default colormap [added in v1.414]
Obtaining date/time from the Kiwi's GPS [fixed in v1.417]
Redirect to the next kiwisdr.
Apparently this happens when the last free slot is trying to occupy 2 users at the same time.I'm not sure what you mean exactly. Do you mean when two users are trying to connect simultaneously to the last channel of the first Kiwi in a redirected chain? (e.g. channel #4 of a 4-channel Kiwi1 that re-directs to Kiwi2). The redirection code was tested pretty carefully. But of course that doesn't mean there isn't a bug someplace.Also, it would be nice at the time of the update to keep the ability to redirect to the next kiwi instead of the update message, if it's real.That's an interesting idea. Hadn't occurred to me before. -
v1.403: colormap improvements, multiple DRM schedule databases
Alright, something has come up and I'm not going to have time to work on the problems with aperture auto mode for a while. So in today's update I've added an "initial aperture" setting to the admin page config tab:v1.409 October 3, 2020 Added "Initial aperture" setting to admin page config tab. This setting determines which waterfall colormap aperture mode, manual or auto, is used as the default for "first time" visitors to your Kiwi. More precisely, for any connection to your Kiwi where the "last aperture set" cookie has not been previously set ("first time" visitors are a subset of that definition). -
Proxy service down or unstable [currently okay]
@Jimo: Not so simple. Not because of the actual code issues, but because of the validation and deployment issues (as usual). Can you imagine the disruption? Especially if something goes wrong?
This is probably best handled when there is the eventual need to open a second proxy server (we're getting close and it will probably be in the EU). That way the migration can be done in a controlled way.
