36,740
670
  • Please protect your KiwiSDR 2 from the high-level RF fields of nearby transmitters
    From your description it certainly sounds like an open attenuator. Especially if you're getting the self-test patterns, just attenuated by 40 dB.
    Please send an email to sales@kiwisdr.nz (note ".nz") requesting a repair. We're having to figure out some sort of formal solution to this problem since a significant number of people are asking.
    Cheeto_Bandito
  • rx.kiwisdr.com (kiwisdr.com/public) list changes
    By request: the list is now sorted in 0-30 MHz SNR order.
    There is a new menu to select the alternate 1.8-30 MHz (HF) order.
    Nate_R
  • v1.698 [iPad "/?m" in URL no longer needed]
    From the CHANGE_LOG file:
    v1.697,698 August 9, 2024
      Fixed problem with iPads where onscreen keyboard pops up with every button press.
      This was due to Apple making non backward-compatible changes to the browser "user agent" string.
      You should no longer need the workaround of adding "/?m" or "/?mobile" to the URL.
      Fixed frequency (and offset) shown in monitor mode panel.
    HB9TMC
  • v1.696
    Yeah, just a bug. Already fixed for the next release.
    Thanks
    studentkra
  • Any plans to move to OpenWebRX Plus? [not possible, makes no sense]
    This question is simply not valid. It doesn't take into account the architectures and evolution of the current Kiwi and owrx systems and how it is not possible to "move" between them. The Kiwi started with some owrx waterfall, sound and user interface Javascript code back in 2014-2016. But things diverged quickly from there.
    owrx runs on a pc. And the Kiwi's Beagle + FPGA is not a pc. That's by design and the root of the issue.
    smg
  • SNR Measurement (timing) enhancement [can be done via cron; /snr?meas url]
    Okay, that wasn't too difficult. Fix will be in the next release (v1.696). It will be a new file called ~/kiwi.config/opt.console.local
    LA6LU
    I turns out that setting is essentially bogus. You can override it easily. I didn't think it through carefully enough when implementing it.
    Even if you're connected as admin from the Internet simply go to the "security" tab and set the switch that says Restrict console connections to the local network? to No. Then refresh the page, then go to the console tab and click Connect. It should now work.
    The problem is that setting can't be in the admin interface. Otherwise it can always be defeated. This feature needs a setting similar to the one that disables the console tab entirely by creating a file called ~/kiwi.config/opt.no_console
    See here: http://kiwisdr.com/info/#id-opt-dot
    LA6LU
  • Forum rules and etiquette
    This is a private, non-public forum for discussing technical topics related to the genuine (original) KiwiSDR product. The forum monthly operating costs are funded out of the profits from selling KiwiSDRs.
    We reserve the right to edit or remove your posts or to ban your participation. If you want to criticize our work that's fine. Just do it somewhere else please. We are all very busy and don't want to spend a lot of time managing chaos on the forum.
    Every single submission is reviewed to meet our content standards. All applicable rules and laws from all the jurisdictions of forum participants are taken into consideration. However, we reject the notion of unadjudicated extraterritorial jurisdiction. You must be of the age of majority in your jurisdiction. You may contact us at support@kiwisdr.com about any matter and we will respond promptly.
    • New participants: Take some time to understand the product, the community, the ecosystem and the limitations that have evolved since the product introduction in 2016. The project authors do not have the resources or capabilities you might think they do.
    • Don't ask support questions about non-genuine KiwiSDR devices. There are other support forums specifically for those devices. If you're not going to support us by buying our stuff you shouldn't be surprised when we don't reciprocate.
    • No "low effort" posts. Search the forum and website FAQ for an answer before asking your question. Yes, our documentation is dismal. But if you complain about a specific point we'll endeavor to document it (or fix the incorrect documentation).
    • Don't complain about well known, long-standing technical limitations such as: audio latency, lack of https/TLS, run-as-root, spotting efficiency of the WSPR extension etc. We know all about these issues and most have been discussed for many years. They are either difficult to solve, have no solution or are way down on the priority list.
    • Don't violate security "zero-day" rules. Don't report security vulnerabilities here or on X/Twitter. Send them to the support email instead.
    • Don't attempt to explain what you think "open source" means. Everyone is wrong about that. Including us. Best interpretation we've seen lately: "Free and Open Source Software" is "Free of Unilateral Control", not "Free of Charge" (i.e. "Free as in Freedom" NOT "Free as in Free Beer")
    Thank you.
    PZNWV
  • Waterfall/Spec smearing when zoomed to WF14 on 4-channel mode [fixed in v1.695]
    Thanks for reporting this.
    It seems the rx4_wf4 FPGA file was incorrectly updated when the v1.692 changes were reapplied in v1.694. But I don't understand why that would of caused this problem. I'll have to go find out.
    This will be fixed as part of v1.695
    nitroengine
  • FT8 6m Autorun [fixed in v1.695]
    Yes, I can do that. Added to my infinite list of things to do..
    Holger
