- jks
- 36,210
- 638
ALE Scan option out of function from now [fixed in v1.810]
eham.net Kiwi review
Someone was kind enough to make a review entry for the Kiwi over on eham.net
If anyone wants to contribute a review to the entry that would be very much appreciated.
Thanks
Debian 11 upgrade for Kiwis using BeagleBone Green/Black
@dl7awl Sorry, there was some missing text on that page describing that the new button on the admin backup tab must be used. I've fixed that now.
@ww6d I'm surprised you thought some sort of formatting of the sd card was necessary. That should not be the case. The procedure writes the new Debian 11 image to the raw sd card device (no formatting required). Then afterwards mounts the created partition on the card to write the Kiwi configuration information.
Also, the documentation section you mention "Re-flashing once you have the SD card" is referenced directly at the end of the upgrade instructions (even including a link!) So there should not have been any confusion about this.
v1.807,808
v1.807,808
Real Time SWBC Shortwave Broadcast Station Schedule
OT: Time Signals for clocks - MSF
Default KiwiSDR DX.json Download
I just replied to your email before I saw this post. So I'll include my email reply here:
So it turns out the default dx.json is stored on every Kiwi in case it turns up missing during a software install. If you bring up the admin console try these commands to see the differences:
cdk
wc ../KiwiSDR/unix_env/kiwi.config/dist.dx.json dx.json
In my case it showed dx.json had a few new lines not present in the default file.
You can replace the "wc" (word count) with a "cp" to copy the default file to the current dx.json. You can use "diff" to see the actual text differences.
You should immediately restart (admin control tab) so the server doesn't overwrite the dx.json file you just restored.
Register Kiwi SDR online
If all channels are full you'd have to "kick" a channel via the button on the admin status page to create a free channel for you to connect.
Alternatively, you can reserve one of the channels by setting a user password on the admin security tab and then set "number of channels not requiring a password even if password is set" to 3 (assuming you're using 4-channel mode). Then that channel will always be available for your use. You won't have to actually give the password if you're connecting from the local network.
You could also use the "camp" interface to wait in queue for a free channel to become available if you don't want to permanently reserve a channel and don't want to kick someone. But you will be waiting an arbitrary amount of time in that case. The camp panel appears automatically when you attempt to connect when all channels are full.
It's fine to use the default serial number as the Kiwi name for a publicly listed Kiwi. Lots of people do that.
KiwiSDR 2 production status
KiwiSDR 2 radios are available again in our online store: https://kiwisdr.nz
Thanks for your support.
