- jks
- 36,729
- 670
VDSL filter for the Kiwi SNR measurement
Well, this entire thing quickly becomes yet another SNR-related rabbit hole. One that I can ill afford at the moment given all the other important stuff I'm working on. I'm only doing it because of a person who is very unhappy the top NZ SNR score is due to VDSL noise.
I should have never added any SNR capability. The project has actually suffered because of it.
I think I'm only allowing 1 user on my KiwiSDR v2. [fixed]
Still determining local interface address??? What's that mean???
I've prototyped a VDSL "filter" to be used with the Kiwi SNR measurement (I used kiwirecorder for the prototyping). I works well for the one Kiwi I know about that has bad VDSL noise, causing it to have inflated SNR values.
If you know of other Kiwi's with this problem please comment here or email support@kiwisdr.com so I can try them out -- Thanks.
Basically, once the VDSL segment is identified it is excluded from the SNR measurement. Same as we have now for masked frequency segments.
kiwirecorder v1.6: netcat / camping modes now support resampling
v1.814,815
"/" is considered one of the keys that are redirected to the frequency field (also 0-9
. , : - # k Menter/return backspace/delete). And that must be terminated by an enter/return. Because instead of a plain "/" you could have typed "/low,high" or "/width" (passband specification) as the frequency field help shows. -
Hackers be hacking..
From the admin console type:
cdk; rm opt.debugand then restart. That will stop those additional logging messages.@smg Running fail2ban would kill the Linux realtime response causing the audio to break up as the Kiwi server process becomes starved for CPU cycles. You can't run a heavy process like a Python interpreter at the same time. We are already extremely lucky that running kernel iptables filtering and user mode frp proxying doesn't cause trouble.
Practical PCB RF design
Wow, one of the few times the YouTube algorithm has recommended an extremely useful video.
In a few minutes I learned more about practical PCB RF design than I ever knew. Very easy to understand: https://www.youtube.com/watch?v=xhuHAhIKWoM
v1.814,815
