can't smoothly drag waterfall [fixed in v1.350,351]
                    Folks,
When I try to drag the waterfall left or right, the interface intermittently acts as if I let go of the left mouse button. I have to release the button, press again and then drag. This happens very intermittently; sometimes I can't drag more than 1/4", other times it's fine. This happens on Windows 10 using Chrome and on Linux using Firefox. Has anyone else seen this? As far as I can tell the mice are working ok.
Thanks
Thanks
(Linux/chrome and linux/firefox)
It's an interesting bug that is a side-effect of the audio FFT added for 8-channel mode. I have a fix ready for the next update. Also fixes for unexpected mouse-related behavior in the frequency scale.
It works wonderful now. Thanks, jks.
(I'm most sorry about the cat, it caught me at a low point).
Interestingly, when in LSB mode, the left hand (lower edge) of the passband display brackets (on the frequency display) can be right against the left edge - and it's not possible to drag it beyond the edge of the screen, which for some receivers/settings can put the lower edge completely off the screen and make it inaccessible - at least on my Windows machines - and on LSB, it's simply not possible to increase the bandwidth as much as it is on USB.
A bit of nit-picking on my part, but it would be more intuitive (to me, at least) to reverse the audio waterfall on LSB (and shift the center to the right of center) so that signals displayed in the passband were in their proper orientation and that full adjustment of bandwidth was possible.
Thanks for your hard work.
Clint
KA7OEI
I guess the comment/question had to do with the visual presentation of the available data rather than what data was actually available: I suppose that if it really bothered me, I could go into the script and fix it myself (e.g. reverse the display of the WF's bins when the BFO was on the high side, offset the CF to visually center the passband, etc.)
Clint
