Location of wsprdaemon.conf
                    Should I have wsprdaemon.conf in both the root of the wsprdaemon directory and in the /tools directory? Because I do have! I am having an issue where I have six wspr monitoring receievers but overnight RX0 or RX1 starts to run a duplicate of one band. Neither wsprdaemon.conf file shows more than six bands entered (both appear identical). Sorry for the newbie question and thanks for any replies. 2E0ILY
Not sure about should but I have just the one, in the username/wsprdaemon/ directory.
I'm running it on a VM so not 100% sure about the default PI full path.
Cheers
Only the WD.conf in the WD.sh directory should be edited by the user.
Also, it is best to stop WD before making edits to WD.conf. i,e: WD -z; vi WD.conf; WD -a
I know Rob says to stop and start the service while editing but what doe he know he's just the guy who wrote it...
Editing here and saving without stopping (using either internal WinSCP editor or my preferred Notepad++) sees the result pop up a minute or two later.
No issues with doing that here but once in every twenty changes I might have to kick a RX instance that has grabbed a "full" channel rather than a no waterfall one.
Alternatively if you prefer a desktop/gui enable VNC on the PI and then use RealVNC viewer, you might have to force the resolution if no monitor is attached..
Actually thinking about it probably better to stop the service edit and restart, I have seen some weird false decodes reported from here and never tied the two together.
Changing the conf of a running WD session will work most of the time. But if your changes remove a running RECEIVER, then WD will no longer know how to shut it down.
