Admin page log [why don't the WSPR decode messages appear in the system log, fixed in v1.334]
Hello
Where is the "history log" from admin tab
Thank you
Rene F6BIR
Thank you
Rene F6BIR
Do you mean the software CHANGE_LOG file? That is located in the source code. Which means on the Kiwi itself it is in the directory /root/Beagle_SDR_GPS/. An easier place to find it is on the github source code repository: https://github.com/jks-prv/Beagle_SDR_GPS/blob/master/CHANGE_LOG
If you mean the
Thank you for answer, in the log ml ms mu do not appear the WSPR decoded stations as in the admin current log.
I can see them on WSPRNET web site, but I would like start an autorun wspr without web connection for a while and to have a local log of decoded stations to evaluate various antennas using crontab and ant_switch extension
Is it possible with the actual version or do you have a good idea to do that
Sorry for the google translate
Regards
Currently the decode messages from the WSPR extension are not "L" messages for this reason. And that is why you don't find them in the system log. However, this could be made an option on the WSPR section of the extensions tab.
v1.334 has a new switch on the WSPR entry of the admin "extensions" tab that allows decodes from WSPR auto-run tasks and use of the WSPR extension to be logged to the syslog. The effect is immediate. No restart is required.
