How is the inactivity time defined? [UI improved in v1.268]
                    Sorry if this question has been discussed earlier ... couldn't find a clear answer off the shelf. I'm running KiwiSDR version 1.266. It seems that the following precondition may not be applied anymore: "The timeout period is reset as soon as some adjustment to the controls is made." Or perhaps I do not know what "the controls" refer to?
We have experienced that if you, for instance, just adjust some of the waterfall settings e.g. "WF Min", it does not seem to be resetting the internal inactivity counter?
So, my question: what are the controls you should be using to get the inactivity counter reset? Also, it would be nice to have a visible inactivity counter somewhere
Thanks & 73, Jari OH6BG
If there is a 24hr use limitation set then a countdown timer is displayed in orange in the user tab of the control panel. But this is not done anywhere yet for the inactivity timer.
From the CHANGE_LOG file:
