Local admin log-in started to ask for password [delayed DHCP server startup]
edited October 2018 in Problems Now Fixed
Using Version 1.237. I have two Kiwis and never set an admin password. Never had any problems with admin log-in using Kiwi address (e.g.) http://192.168.1.103:8073/admin from PC (IP 192.168.1.196) on same router. When local log-in was working, the Log detail showed that the PC IP was recognised as a local log-in. Nothing has changed but this morning I get asked for a password on both Kiwis. Using kiwisdr.local:8073/admin gets an "unable to connect" page. I can stiil log in to the Kiwi using PuTTY and root password. I'm sure it's something simple but I've trawled through previous posts and can't find anything similar. I am not a Linux expert so if the solution needs access through PuTTY to change config files, please provide some clues!! Thanks in advance.
    edited October 2018
    Couple of questions:
    Is either of these Kiwis accessible from the Internet? If so, what's the URL?
    You say "started to ask for password" and then later "unable to connect" (browser saying that?). These are not the same thing. Which is it?
    If you can login as root to the Beagle then you can check for an admin password being set. But this almost certainly is not going to be the case. Type "cdk" to change to the configuration directory and then "more admin.json". Towards the start of the output you should see "admin_password":"" if no password has been set.
    Can you cut-and-paste the relevant messages from the log? They'll be like:
    Thu Oct  4 07:42:01 00:03:40.436 0...     [02]   PWD isLocal_if_ip: flg=0x18 fam=2 socktype=1 proto=6 addrlen=16 192.168.1.6
    Thu Oct  4 07:42:01 00:03:40.437 0...     [02] L PWD isLocal_if_ip: TRUE IPv4/4_6 remote_ip 192.168.1.6 ip_client 192.168.1.6/0xc0a80106 ip_server[IPv4] 192.168.1.103/0xc0a80167 nm /24 0xffffff00
    Thu Oct  4 07:42:01 00:03:40.437 0...     [02] L PWD admin config pwd set FALSE, auto-login TRUE
    Thu Oct  4 07:42:01 00:03:40.438 0...     [02] L PWD admin ALLOWED: no config pwd set, but is_local
    Thu Oct  4 07:42:01 00:03:40.438 0...     [02] L PWD admin ALLOWED: from 192.168.1.6
  • Sorry - admin password had been set.
    Following your instructions to look at the log through PuTTY - an admin password HAS been set and I have now used it successfully to get into the web admin interface and now I am able to look at the webAdmin security Tab and see the password, although the "Admin auto-login from local net even if password set?" is set to "Yes"
    I think I must be losing my marbles as I cannot remember setting a password and if I did it must have been in the last two days... I am sorry to have wasted your time. Although I would never have solved the problem without your instructions to check the log via PuTTY.
    Just to clarify the Local log-in "issue":
    If I use the full local IP address: http://192.168.1.103:8073/admin then password is (now) requested
    If I use: kiwisdr.local:8073/admin then I get "Unable to connect"
    However it is possible that "kiwisdr.local:8073/admin" has never worked as I have always used the full local IP address. My PCs are in a Windows Workgroup, the Kiwis are not.
    Map display
    Both Kiwis were visible on the map but just checked the map and now they are not. They are still accessible using
    http://g0ezy-kiwisdr.ddns.net:8073/ and
    http://g0ezy-kiwisdr.ddns.net:8079/
    I can see in the Log, many reports of "sdr.hu registration: DOWN" so now going to sort that out
    Thanks for your help
    Terry
  • Finally - realised what has happened. We have had mains supply problems. Kiwis rebooted before the router started so not supplied with IP and allocated their own address. When router started and addresses available the Kiwis kept their "Private IP address (inside your firewall/router)". After rebooting the Kiwis, the Router IP address replaced the default address and now all is back to normal and are showing on sdr.hu map.
  • Okay, this makes more sense now. Looking at your log messages I see this when an admin connection was attempted 37 seconds after reboot:
    Thu Oct  4 09:49:34 00:00:37.025 ..23....     [04] PWD isLocal_if_ip: flg=0x18 fam=2 socktype=1 proto=6 addrlen=16 192.168.1.196
    Thu Oct  4 09:49:34 00:00:37.025 ..23....     [04] PWD isLocal_if_ip: IPv4 client, but no server IPv4/IPv4_6
    Thu Oct  4 09:49:34 00:00:37.028 ..23....     [04] PWD admin config pwd set TRUE, auto-login TRUE
    Thu Oct  4 09:49:34 00:00:37.030 ..23....     [04] PWD admin CAN'T DETERMINE: no local network interface information
    So yes, the Kiwi hadn't been able to determine its local address at that point. So local network auto-login would not be able to override and you were asked for the admin password. 02:44 after boot the Kiwi is finally able to get a response to its DHCP request (assigned the .103 address) and in turn start DDNS opening the port on your router:
    Thu Oct  4 09:51:41 00:02:44.259 ..23....          DDNS: public ip xx.xx.xx.xx
    Thu Oct  4 09:51:41 00:02:44.266 ..23....          DDNS: private IPv4 <192.168.1.103> 0xc0a80167 /24 0xffffff00
    Thu Oct  4 09:51:41 00:02:44.266 ..23....          DDNS: private IPv6  /64 ff:ff:ff:ff:ff:ff:ff:ff:00:00:00:00:00:00:00:00:
    Thu Oct  4 09:51:41 00:02:44.266 ..23....          DDNS: private IPv6 LINK-LOCAL  /64 ff:ff:ff:ff:ff:ff:ff:ff:00:00:00:00:00:00:00:00:
    And at 05:29 an admin connection without requiring the password succeeds:
    Thu Oct  4 09:54:26 00:05:29.653 ..23....     [04] PWD isLocal_if_ip: flg=0x18 fam=2 socktype=1 proto=6 addrlen=16 192.168.1.196
    Thu Oct  4 09:54:26 00:05:29.653 ..23....     [04] PWD isLocal_if_ip: TRUE IPv4/4_6 remote_ip 192.168.1.196 ip_client 192.168.1.196/0xc0a801c4 ip_server[IPv4] 192.168.1.103/0xc0a80167 nm /24 0xffffff00
    Thu Oct  4 09:54:26 00:05:29.657 ..23....     [04] PWD admin config pwd set TRUE, auto-login TRUE
    Thu Oct  4 09:54:26 00:05:29.659 ..23....     [04] PWD admin ALLOWED: config pwd set, but is_local and auto-login set
    Thu Oct  4 09:54:26 00:05:29.659 ..23....     [04] PWD admin ALLOWED: from 192.168.1.196
