Local admin log-in started to ask for password [delayed DHCP server startup]
Using Version 1.237. I have two Kiwis and never set an admin password. Never had any problems with admin log-in using Kiwi address (e.g.) http://192.168.1.103:8073/admin from PC (IP 192.168.1.196) on same router. When local log-in was working, the Log detail showed that the PC IP was recognised as a local log-in. Nothing has changed but this morning I get asked for a password on both Kiwis. Using kiwisdr.local:8073/admin gets an "unable to connect" page. I can stiil log in to the Kiwi using PuTTY and root password. I'm sure it's something simple but I've trawled through previous posts and can't find anything similar. I am not a Linux expert so if the solution needs access through PuTTY to change config files, please provide some clues!! Thanks in advance.
Is either of these Kiwis accessible from the Internet? If so, what's the URL?
You say "started to ask for password" and then later "unable to connect" (browser saying that?). These are not the same thing. Which is it?
If you can login as root to the Beagle then you can check for an admin password being set. But this almost certainly is not going to be the case. Type "cdk" to change to the configuration directory and then "more admin.json". Towards the start of the output you should see "admin_password":"" if no password has been set.
Can you cut-and-paste the relevant messages from the log? They'll be like:
Following your instructions to look at the log through PuTTY - an admin password HAS been set and I have now used it successfully to get into the web admin interface and now I am able to look at the webAdmin security Tab and see the password, although the "Admin auto-login from local net even if password set?" is set to "Yes"
I think I must be losing my marbles as I cannot remember setting a password and if I did it must have been in the last two days... I am sorry to have wasted your time. Although I would never have solved the problem without your instructions to check the log via PuTTY.
Just to clarify the Local log-in "issue":
If I use the full local IP address: http://192.168.1.103:8073/admin then password is (now) requested
If I use: kiwisdr.local:8073/admin then I get "Unable to connect"
However it is possible that "kiwisdr.local:8073/admin" has never worked as I have always used the full local IP address. My PCs are in a Windows Workgroup, the Kiwis are not.
Map display
Both Kiwis were visible on the map but just checked the map and now they are not. They are still accessible using
http://g0ezy-kiwisdr.ddns.net:8073/ and
http://g0ezy-kiwisdr.ddns.net:8079/
I can see in the Log, many reports of "sdr.hu registration: DOWN" so now going to sort that out
Thanks for your help
Terry
