kiwirecorder.py crashes
In kiwiwspr.sh I utilize kiwirecorder.py to capture the WSPR band audio to a wav file and then process that wav file using 'wsprd'
As I increase the number of kiwirecorder.py, more and more often my kiwirecorder.py will crash and need to be restarted by my watchdog daemon.
These failures occur with the same frequency at two different QTHs and on the more powerful odroid as often as on the Pi.
I have monitored the ethernet packet loss rate which is very, very low and there seems to be no correlation between crashes and the few lost packets reported by a simultaneous iperf udp stream.
As an example, I execute:
python -u /home/odroid/ham/kiwiwspr/kiwiclient-jks-v0.1/kiwirecorder.py -q --ncomp -s 10.14.70.75 -p 8073 -f 28124.6 -m usb -L 1200 -H 1700 --pw=foobar -T -101 --dt-sec 120 >> capture.log 2>&1 &
And 5 minutes later that spawned capture terminates with this diagnostic printout:
Started a new file: 20180927T162400Z_28124600_usb.wav
Traceback (most recent call last):
File "/home/odroid/ham/kiwiwspr/kiwiclient-jks-v0.1/kiwiworker.py", line 39, in run
self._recorder.run()
File "/home/odroid/ham/kiwiwspr/kiwiclient-jks-v0.1/kiwiclient.py", line 359, in run
received = self._stream.receive_message()
File "/home/odroid/ham/kiwiwspr/kiwiclient-jks-v0.1/mod_pywebsocket/_stream_hybi.py", line 797, in receive_message
self._process_ping_message(message)
File "/home/odroid/ham/kiwiwspr/kiwiclient-jks-v0.1/mod_pywebsocket/_stream_hybi.py", line 688, in _process_ping_message
self._send_pong(message)
File "/home/odroid/ham/kiwiwspr/kiwiclient-jks-v0.1/mod_pywebsocket/_stream_hybi.py", line 888, in _send_pong
self._options.outgoing_frame_filters)
File "/home/odroid/ham/kiwiwspr/kiwiclient-jks-v0.1/mod_pywebsocket/_stream_hybi.py", line 368, in create_pong_frame
return _create_control_frame(common.OPCODE_PONG, body, mask, frame_filters)
File "/home/odroid/ham/kiwiwspr/kiwiclient-jks-v0.1/mod_pywebsocket/_stream_hybi.py", line 360, in _create_control_frame
return _build_frame(header, frame.payload, mask)
File "/home/odroid/ham/kiwiwspr/kiwiclient-jks-v0.1/mod_pywebsocket/_stream_hybi.py", line 139, in _build_frame
return header + masking_nonce + masker.mask(body)
File "/home/odroid/ham/kiwiwspr/kiwiclient-jks-v0.1/mod_pywebsocket/util.py", line 201, in _mask_using_array
result.fromstring(s)
TypeError: fromstring() argument 1 must be string or read-only buffer, not bytearray
GNSS position: lat,lon=[+38.10, -122.95]
Started a new file: 20180927T163912Z_28124600_usb.wav
This is by no means a crisis problem, but I suspect that other kiwirecorder.py users like the TDoA service may be encountering similar problems.
I have a fix for these crashes, waiting for @jks to merge them into his fork of kiwiclient.
These crashes were caused by changes for python2/python3 compatibility.
Started a new file: 20180928T231200Z_14095600_usb.wav
Started a new file: 20180928T231400Z_14095600_usb.wav
File "/home/pi/ham/kiwiwspr/kiwiclient-jks-v0.1/kiwiworker.py", line 40, in run
File "/home/pi/ham/kiwiwspr/kiwiclient-jks-v0.1/kiwiclient.py", line 361, in run
File "/home/pi/ham/kiwiwspr/kiwiclient-jks-v0.1/mod_pywebsocket/_stream_hybi.py", line 757, in receive_message
frame = self._receive_frame_as_frame_object()
File "/home/pi/ham/kiwiwspr/kiwiclient-jks-v0.1/mod_pywebsocket/_stream_hybi.py", line 462, in _receive_frame_as_frame_object
opcode, unmasked_bytes, fin, rsv1, rsv2, rsv3 = self._receive_frame()
File "/home/pi/ham/kiwiwspr/kiwiclient-jks-v0.1/mod_pywebsocket/_stream_hybi.py", line 459, in _receive_frame
unmask_receive=self._options.unmask_receive)
File "/home/pi/ham/kiwiwspr/kiwiclient-jks-v0.1/mod_pywebsocket/_stream_hybi.py", line 194, in parse_frame
received = receive_bytes(2)
File "/home/pi/ham/kiwiwspr/kiwiclient-jks-v0.1/mod_pywebsocket/_stream_hybi.py", line 454, in _receive_bytes
return self.receive_bytes(length)
File "/home/pi/ham/kiwiwspr/kiwiclient-jks-v0.1/mod_pywebsocket/_stream_base.py", line 159, in receive_bytes
new_read_bytes = self._read(length)
File "/home/pi/ham/kiwiwspr/kiwiclient-jks-v0.1/mod_pywebsocket/_stream_base.py", line 119, in _read
(length, (self._request.connection.remote_addr,)))
ConnectionTerminatedException: Receiving 2 byte failed. Peer ((('10.14.70.76', 8073),)) closed connection
GNSS position: lat,lon=[+38.09, -122.95]
Started a new file: 20180928T231512Z_14095600_usb.wav
Started a new file: 20180928T231600Z_14095600_usb.wav
Here is the python output from the 20M client session which failed at 0624:
Started a new file: 20180929T062400Z_14095600_usb.wav
File "/home/pi/ham/kiwiwspr/kiwiclient-jks-v0.1/mod_pywebsocket/_stream_base.py", line 128, in _read
(length, e))
ConnectionTerminatedException: Receiving 2 byte failed. socket.error (timed out) occurred
Started a new file: 20180929T062710Z_14095600_usb.wav
Here is the /var/log/messages from the Kiwi which reports all of the 8 client sessions which were restarted at that time:
Sep 29 06:25:11 kiwisdr rsyslogd: [origin software="rsyslogd" swVersion="8.4.2" x-pid="427" x-info="http://www.rsyslog.com"] rsyslogd was HUPed
Sep 29 06:25:12 kiwisdr kiwid: 6d:07:39:56.635 012.4567 3 7040.05 kHz usb z0 "kiwirecorder.py" 10.14.70.84 Point Reyes Station, California, USA (LEAVING after 7:10:23)
Sep 29 06:25:12 kiwisdr kiwid: 6d:07:39:56.638 0.2.4567 1 28126.05 kHz usb z0 "kiwirecorder.py" 10.14.70.84 Point Reyes Station, California, USA (LEAVING after 7:10:00)
Sep 29 06:25:12 kiwisdr kiwid: 6d:07:39:56.646 0.2.456. 7 3594.05 kHz usb z0 "kiwirecorder.py" 10.14.70.84 Point Reyes Station, California, USA (LEAVING after 7:10:06)
Sep 29 06:25:12 kiwisdr kiwid: 6d:07:39:56.664 0.2.45.. 6 21096.05 kHz usb z0 "kiwirecorder.py" 10.14.70.84 Point Reyes Station, California, USA (LEAVING after 7:10:20)
Sep 29 06:25:12 kiwisdr kiwid: 6d:07:39:56.667 0...45.. 2 3570.05 kHz usb z0 "kiwirecorder.py" 10.14.70.84 Point Reyes Station, California, USA (LEAVING after 7:10:24)
Sep 29 06:25:12 kiwisdr kiwid: 6d:07:39:56.671 0....5.. 4 10140.15 kHz usb z0 "kiwirecorder.py" 10.14.70.84 Point Reyes Station, California, USA (LEAVING after 7:10:22)
Sep 29 06:25:12 kiwisdr kiwid: 6d:07:39:56.671 0....... 5 18106.05 kHz usb z0 "kiwirecorder.py" 10.14.70.84 Point Reyes Station, California, USA (LEAVING after 7:10:20)
Sep 29 06:25:12 kiwisdr kiwid: 6d:07:39:56.675 ........ 0 14097.05 kHz usb z0 "kiwirecorder.py" 10.14.70.84 Point Reyes Station, California, USA (LEAVING after 7:10:03)
Sep 29 06:27:04 kiwisdr kiwid: 6d:07:41:48.551 ..2..... 2 0.00 kHz am z0 "kiwirecorder.py" 10.14.70.84 (ARRIVED)
Sep 29 06:27:04 kiwisdr kiwid: 6d:07:41:49.378 ..23.... 3 0.00 kHz am z0 "kiwirecorder.py" 10.14.70.84 (ARRIVED)
Sep 29 06:27:05 kiwisdr kiwid: 6d:07:41:50.165 ..234... 4 0.00 kHz am z0 "kiwirecorder.py" 10.14.70.84 (ARRIVED)
Sep 29 06:27:06 kiwisdr kiwid: 6d:07:41:50.961 ..2345.. 5 0.00 kHz am z0 "kiwirecorder.py" 10.14.70.84 (ARRIVED)
Sep 29 06:27:07 kiwisdr kiwid: 6d:07:41:51.702 ..23456. 6 0.00 kHz am z0 "kiwirecorder.py" 10.14.70.84 (ARRIVED)
Sep 29 06:27:08 kiwisdr kiwid: 6d:07:41:53.357 ..234567 7 0.00 kHz am z0 "kiwirecorder.py" 10.14.70.84 (ARRIVED)
Sep 29 06:27:09 kiwisdr kiwid: 6d:07:41:54.122 0.234567 0 0.00 kHz am z0 "kiwirecorder.py" 10.14.70.84 (ARRIVED)
I can reproduce the backtraces you are seeing by kicking out a connection from the admin tab. So it looks like the kiwisdr kicks out one of the connections for whatever reason. I guess you are running one instance of kiwirecorder.py recording 8 data streams, so if any one of them throws an exception, all of them terminate.
You see this backtrace because the kiwirecorder does not expect that the server closes the connection. In addition the server does not send a close request to the websocket client. I have fixes for both of these issues and I guess that John will let you know when they are available.
Do you have anything interesting in /var/log/messages before the 1st client leaves?
Sep 24 16:05:17 kiwisdr kiwid: 1d:17:20:01.635 01234567 ca_pause 16377 ca_pause_old 9 ca_shift=56 code_creep=-65 code_period_ms=1 code_period_samples=16368
Sep 25 03:28:01 kiwisdr kiwid: 2d:04:42:45.909 01234567 UPDATE: check scheduled
Sep 25 06:25:10 kiwisdr rsyslogd: [origin software="rsyslogd" swVersion="8.4.2" x-pid="427" x-info="http://www.rsyslog.com"] rsyslogd was HUPed
Sep 26 03:28:01 kiwisdr kiwid: 3d:04:42:45.898 01234567 UPDATE: check scheduled
Sep 26 06:25:10 kiwisdr rsyslogd: [origin software="rsyslogd" swVersion="8.4.2" x-pid="427" x-info="http://www.rsyslog.com"] rsyslogd was HUPed
Sep 26 06:25:11 kiwisdr kiwid: 3d:07:39:55.976 0123456. 7 10140.15 kHz usb z0 "kiwirecorder.py" 10.14.70.84 Point Reyes Station, California, USA (LEAVING after 40:47:54)
Sep 26 06:25:11 kiwisdr kiwid: 3d:07:39:55.984 01234.6. 5 18106.05 kHz usb z0 "kiwirecorder.py" 10.14.70.84 Point Reyes Station, California, USA (LEAVING after 47:58:02)
WA2ZKD points out that 0627 seems to be a common time for these events to occur.
However I can increase the frequency of these failures by increasing the number of simultaneous kiwirecorder.py clients. When I run 20 clients the CPU is only 30% busy and there is only 4 Mbps of ethernet traffic, but failures will occur several times per hour.
I can give you ssh access to such a system if it would help your debugging.
How can I duplicate the more frequent crashing scenario so I might see what's happening on the Kiwi side? In particular what does "run 20 clients" mean exactly? That you're using multiple Kiwi servers and instances of kiwiclient such that there are 20 simultaneous open network connections? And, as Christoph asked, does is each kiwiclient setup to make 8 connections or only one? (i.e. does seeing 8 connections disappear from the Kiwi log reflect that one instance of kiwiclient, with 8 connections, has exited or that the Kiwi has kicked all connections causing 8 instances of kiwiclient to exit?)
I've found a bunch of little problems with kiwirecorder, but nothing that explains why the Kiwi might be exhibiting the disconnection behavior. I just checked in these changes along with your v1.0 kiwiwspr script in the tools/ subdirectory. I'll keep look for the problem..
So now I can make 8 connections to an 8-channel Kiwi and then proceed to use the "kick" button (admin page status tab) on any combination of channels and the retry code in kiwirecorder will soon reconnect those channels. This occurs whether I use 8 instances of kiwirecorder each making a single connection or a single instance that makes 8 connections. See the Makefile targets "crash" and "crash2". And also the new targets "ps, kp, kill" which makes it a bit easier to manage multiple kiwirecorder processes that run detached.
You mentioned that the CPU load is 30% with 20 clients but I guess that this is for recording only because every two minutes 20 wspr decoding processes will be running in parallel.
So you could try to give the wspr decoding processes less priority and/or run them sequentially instead of in parallel.
In summary I think that the CPU load of the wspr decoders slows down the recorders to a point where timeouts (either on client or on server side) are exceeded. Note that this is also consistent with your observation that the frequency of crashes depends on the number of recorders (+wspr decoders) running.
When it happened before (to best recollection) it would have been an all-or-nothing when I restarted something in the network link.
I 'nice' the wsprd jobs, and the crash rates seems to be the same on the Pi and the odroid, so I don't think its an out of CPU or ethernet IO problem. I left an i5 Mac Air out at KPH and can compare the crash rate on it against the Pi when I fix my scheduling bug, but I'll be upping CPU performance and changing OS at the same time. I don't own an x86 Linux server, but one of my beta testers runs on one but he has only one Kiwi.
Thanks
The Kiwi is currently connecting over a wireless bridge (two Microtik devices) so I suppose there is some possibility there could be a momentary glitch as my neighbours overly powerful AP's hog channels (mine are running 3dbm with a link of about four feet).
The message "rsyslogd was HUPed means that the system logs were rotated.
I suspect that you will find similar log entries or log entries related to other software than kiwid before each kiwirecorder crash. Can you check?
I have finished fixing my kiwiwspr.sh version 1.1 script and have been running 19 WSPR client jobs with it for an hour on what is now a very busy (and warm) Pi3B with no crashes or restarts. Previously I would see crashes every few minutes under these conditions. So you and John have made dramatic improvements in its stability in the last week.
With those crashes gone my log files are completely clean, so any errors stimulated by logrotate or other kiwi or pi system activity should be easily visible.
With my and your fixes, I think kiwiwspr.sh is ready for production use. I'll be posting it in another discussion thread. Thanks
In 19 hours of testing on 19 simultaneous recording sessions I have observed 2 crashes.
========= The first crash occurred on Kiwi KPH_HF_2 at 08:23 PDT == 15:23 UDT after 19 hours of operation when this message was logged by kiwirecorder: =================
File "/home/pi/ham/kiwiwspr/kiwiclient-jks-v0.1/kiwiworker.py", line 42, in run
File "/home/pi/ham/kiwiwspr/kiwiclient-jks-v0.1/kiwiclient.py", line 372, in run
AttributeError: 'Stream' object has no attribute '_options'
===== Kiwi KPH_HF_2's /var/log/messages has log entries at that time, but nothing else in the system logged at that time =========
Oct 2 06:25:38 kiwisdr kiwid: 6d:15:46:58.091 01234567 0 GEOLOC: geoloc_task:P2:T30((50.000 msec) TaskSleep)
Oct 2 06:27:17 kiwisdr rsyslogd0: action 'action 17' resumed (module 'builtin:ompipe') [try http://www.rsyslog.com/e/0 ]
Oct 2 06:27:17 kiwisdr rsyslogd-2359: action 'action 17' resumed (module 'builtin:ompipe') [try http://www.rsyslog.com/e/2359 ]
Oct 2 15:22:32 kiwisdr kiwid: 7d:00:43:52.287 01234.67 5 10140.15 kHz usb z0 "kiwirecorder.py" 10.14.70.84 Point Reyes Station, California, USA (LEAVING after 8:57:16)
Oct 2 15:23:03 kiwisdr kiwid: 7d:00:44:23.373 01234567 5 0.00 kHz am z0 "kiwirecorder.py" 10.14.70.84 (ARRIVED)
Oct 2 15:23:15 kiwisdr kiwid: 7d:00:44:35.089 01234567 5 GEOLOC: 10.14.70.84 sent no geoloc info, trying from here
Oct 2 15:23:15 kiwisdr kiwid: 7d:00:44:35.726 01234567 5 GEOLOC: ipapi.co/198.40.45.23/json
Oct 2 20:14:29 kiwisdr kiwid: 7d:05:35:49.149 01234567 ca_pause 16375 ca_pause_old 7 ca_shift=16 code_creep=-23 code_period_ms=1 code_period_samples=16368
========= The second crash occurred on Kiwi KPH_HF_3 at 08:51 PDT == 15:51 UDT when this message was logged by kiwirecorder: =================
File "/usr/lib/python2.7/logging/__init__.py", line 861, in emit
msg = self.format(record)
File "/usr/lib/python2.7/logging/__init__.py", line 734, in format
return fmt.format(record)
File "/usr/lib/python2.7/logging/__init__.py", line 465, in format
record.message = record.getMessage()
File "/usr/lib/python2.7/logging/__init__.py", line 325, in getMessage
msg = str(self.msg)
TypeError:
Logged from file kiwiclient.py, line 272
File "/home/pi/ham/kiwiwspr/kiwiclient-jks-v0.1/kiwiclient.py", line 379, in run
self._process_ws_message(received)
File "/home/pi/ham/kiwiwspr/kiwiclient-jks-v0.1/kiwiclient.py", line 164, in _process_ws_message
self._process_message(tag, body)
File "/home/pi/ham/kiwiwspr/kiwiclient-jks-v0.1/kiwiclient.py", line 275, in _process_message
self._set_keepalive()
File "/home/pi/ham/kiwiwspr/kiwiclient-jks-v0.1/kiwiclient.py", line 159, in _set_keepalive
self._send_message('SET keepalive')
File "/home/pi/ham/kiwiwspr/kiwiclient-jks-v0.1/kiwiclient.py", line 144, in _send_message
self._stream.send_message(str(msg))
TypeError:
2018-10-02 08:50:41,761 pid 23176 websocket close: "Required argument 'source' (pos 1) not found"
pi@PiKPH:/tmp/kiwi-captures $
===== Kiwi KPH_HF_3's /var/log/messages has log entries at that time, but nothing in the system logged at that time =========
Oct 2 06:25:11 kiwisdr rsyslogd: [origin software="rsyslogd" swVersion="8.4.2" x-pid="427" x-info="http://www.rsyslog.com"] rsyslogd was HUPed
Oct 2 15:50:41 kiwisdr kiwid: 9d:17:05:26.262 012.4567 3 3594.05 kHz usb z0 "kiwirecorder.py" 10.14.70.84 Point Reyes Station, California, USA (LEAVING after 17:28:50)
Oct 2 15:51:03 kiwisdr kiwid: 9d:17:05:48.293 01234567 3 0.00 kHz am z0 "kiwirecorder.py" 10.14.70.84 (ARRIVED)
Oct 2 15:51:21 kiwisdr kiwid: 9d:17:06:05.903 01234567 3 GEOLOC: 10.14.70.84 sent no geoloc info, trying from here
Oct 2 15:51:22 kiwisdr kiwid: 9d:17:06:06.568 01234567 3 GEOLOC: ipapi.co/198.40.45.23/json
Fatal Python error: GC object already tracked
there is an update to the kiwirecorder code which you may try.
1st crash: "AttributeError: 'Stream' object has no attribute '_options'"
* There may be a fix for this in the update
2nd crash: "self._stream.send_message(str(msg)) TypeError:"
* I do not understand how str(msg) can throw an exception. Anyway calling str in this case is not needed and it is removed in the update
3rd crash: "Fatal Python error: GC object already tracked"
* for the update I started to look at the state of the garbage collector and found and removed some cyclic dependencies (one caused by OptionParser and another one due to some import statements)
Thanks for these crash reports as they help to improve the software!
The first crash occurred about 90 minutes after startup:
pi@PiKPH:/tmp/kiwi-captures $ cat KPH_HF_3/30/capture.log
File "/home/pi/ham/kiwiwspr/kiwiclient-jks-v0.1/kiwiworker.py", line 35, in run
File "/home/pi/ham/kiwiwspr/kiwiclient-jks-v0.1/kiwiclient.py", line 377, in run
File "/home/pi/ham/kiwiwspr/kiwiclient-jks-v0.1/kiwiclient.py", line 159, in _process_ws_message
tag = message[0:3].decode('utf-8')
File "/usr/lib/python2.7/encodings/utf_8.py", line 16, in decode
return codecs.utf_8_decode(input, errors, True)
TypeError: an integer is required
The second crash occurred several minutes ago after 6 hours of operation, but it generated no printout information. The watchdog daemon checked the pid every two minutes and it found it dead. The log file for that pid is empty:
pi@PiKPH:/tmp/kiwi-captures $ cat KPH_HF_2/80/capture.log
At least the first crash appears to be in a new area of your code. I'll continue testing...
The fourth occured about 2 hours later and produced the same output as I reported above:
pi@PiKPH:/tmp/kiwi-captures $ cat KPH_HF_3/17/capture.log
pi@PiKPH:~/ham/kiwiwspr $ ls -ld kiwiclient-jks-v0.1*
drwxr-xr-x 4 pi pi 4096 Oct 4 07:30 kiwiclient-jks-v0.1
drwxr-xr-x 4 pi pi 4096 Oct 7 07:24 kiwiclient-jks-v0.1.broken
pi@PiKPH:~/ham/kiwiwspr $ /home/pi/ham/kiwiwspr/kiwiclient-jks-v0.1/kiwirecorder.py -q --ncomp -s 10.14.70.76 -p 8073 -f 28124.6 -m usb -L 1200 -H 1700 --pw=littledavey -T -101 --dt-sec 120
^CKeyboardInterrupt: threads successfully closed
pi@PiKPH:~/ham/kiwiwspr $ /home/pi/ham/kiwiwspr/kiwiclient-jks-v0.1.broken/kiwirecorder.py -q --ncomp -s 10.14.70.76 -p 8073 -f 28124.6 -m usb -L 1200 -H 1700 --pw=littledavey -T -101 --dt-sec 120
2018-10-07 10:55:21,557 pid 13857 integer argument expected, got float
2018-10-07 10:55:21,559 pid 13857 integer argument expected, got float
2018-10-07 10:55:21,579 pid 13857 integer argument expected, got float
2018-10-07 10:55:21,623 pid 13857 integer argument expected, got float
2018-10-07 10:55:21,666 pid 13857 integer argument expected, got float
2018-10-07 10:55:21,711 pid 13857 integer argument expected, got float
2018-10-07 10:55:21,756 pid 13857 integer argument expected, got float
2018-10-07 10:55:21,800 pid 13857 integer argument expected, got float
2018-10-07 10:55:21,844 pid 13857 integer argument expected, got float
2018-10-07 10:55:21,892 pid 13857 integer argument expected, got float
2018-10-07 10:55:21,914 pid 13857 integer argument expected, got float
2018-10-07 10:55:21,958 pid 13857 integer argument expected, got float
2018-10-07 10:55:22,003 pid 13857 integer argument expected, got float
2018-10-07 10:55:22,047 pid 13857 integer argument expected, got float
2018-10-07 10:55:22,091 pid 13857 integer argument expected, got float
2018-10-07 10:55:22,135 pid 13857 integer argument expected, got float
2018-10-07 10:55:22,180 pid 13857 integer argument expected, got float
2018-10-07 10:55:22,224 pid 13857 integer argument expected, got float
2018-10-07 10:55:22,268 pid 13857 integer argument expected, got float
2018-10-07 10:55:22,312 pid 13857 integer argument expected, got float
2018-10-07 10:55:22,357 pid 13857 integer argument expected, got float
2018-10-07 10:55:22,401 pid 13857 integer argument expected, got float
2018-10-07 10:55:22,445 pid 13857 integer argument expected, got float
^C2018-10-07 10:55:22,489 pid 13857 integer argument expected, got float
