New User - thoughts / issues
                    First of all. I LOVE the project and I have quite a bit to learn.  I do see massive potential for some fun things to do with this.  I like how you've expanded openwebrx to the area it needs to go AND MORE! However there are a few things I was wondering if were possible.
1) Presets - I really like to flip around known channels / favorites but it is a manual process. I know you can do last/previous with the arrow keys but I'd like some form of bookmark/favorites extension. A simple list on the left hand side would suffice with maybe folders/sub folders!
2) Is there enough processing power left to do Morse/TTY or other CW type stuff?
3) Right click options are very nice. The 2nd option for utility lookup never seems to find anything. Sure it is set up correctly? How do I confirm?
4) Any way to incorporate a right click to go to the appropriate frequency range at https://www.sigidwiki.com/wiki/Signal_Identification_Guide ? /vlf/lf/mf etc as a quick reference?
5) I've been having very odd noise issues. It seems on every odd/even band at equal distant points I see a small signal with nothing on it. It varies from day/night but it is like every 1-10KHz there is a signal. I also get a LOT of AM radio echos on different frequencies. I've ordered an AM radio bandstop to see if it'll eliminate any noise.
6) The unit came with a whole slew of presets that were not applicable to my geographic location. I've been manually removing a lot of them. Would be nice if there was some way for people to share their presets for different continents maybe. So if I do a thorough set of bookmarks for the Midwest etc, I could share them.
7) Any chance of switching to SSL?
FYI I use a mini whip with no filters currently on my TV antenna tripod and my setup can be heard here (although it isn't permanent location) 24.146.41.3:8073
Here is one of the posts on sharing: http://forum.kiwisdr.com/discussion/862/repository-of-dx-json
People believe the bad guys can't get to you and "the gubmint" can't read traffic "because SSL", it's more accurate to say script kiddies who can't use YouTube probably will try someone else first due to your use of SSL.
That said if you have a local server running LetsEncrypt with a wildcard on your public IP could that not cover it?
Websdr has the "memories" section that really helps. No logging in needed. Site just remembers you and your prefs.
The question with all those frontend improvements is "Where to put them in the UI?" The space is tight.
"Presets - I really like to flip around known channels / favorites but it is a manual process. I know you can do last/previous with the arrow keys but I'd like some form of bookmark/favorites extension. A simple list on the left hand side would suffice with maybe folders/sub folders! "
Although it's not quite what you had in mind, you can get close by bookmarking URL strings.
If you use the green arrow button next to the frequency input text box, it opens up a new browser session with a URL string including the current frequency and mode etc. This can then be saved as a browser bookmark and renamed as required.
I also do this for TDoA sessions and save them with names such as UK, Europe, North America, Russia, China etc.
That way I can quickly recall some standard setups with KiWi's that I know work well for the named coverage area, then I normally only have to recall the bookmark, change the frequency and hit submit.
It saves a lot of time if you ever need to quickly locate a transmission.
