Simultaneous local and autostart WSPR fails [can't seem to reproduce]
It appears that if one or more autostart WSPR sessions are running that adding another WSPR from the user interfaces fails after the first decode. The waterfall stops progressing and no more signals are decoded. The pre-existing autostart sessions do seem to continue OK.
Can anyone else confirm this?
What happens when you run 4 UI sessions, and no autoruns, on that Kiwi? Is this just a generic problem with the connection?
If it shows up again I'll try multiple UI's and other combinations.
