Repository of dx.json
                    I would be happy to host a repository of dx.json files on a public/free access Dropbox site. Mail me your file at jim@jimlill.com renamed <your_callsign.json>
                            Files will be at
Ron Morell
Don't listen to me, this sounds like to much effort.
Ron Morell
Ron Morell
That's all that is required, just refresh your browser session to see the new entries.
So is possible to share between users the dx.json? is it a editable database? can I merge different files dx.json?
It would be great to work on a big file with thousand frequencies.
Giulio IZ3EAW
It is possible to edit or replace the JSON file that stores the information (/root/kiwi.config/dx.json). But if you make a mistake you have to look at the Kiwi log which will try to give you some information about where you made a mistake with the JSON syntax.
it may be relevant for other northeast US kiwi and a better starting point that the one that comes with a kiwi
cd /root/kiwi.config
wget https://www.dropbox.com/s/envtq0zl33t3bas/dx.zkd_apr2019?dl=0
mv dx.zkd_apr2019\?dl\=0 dx.zkd
you will then have your original dx.json and the dx.zkd file in the same sub-dir
Cheers..
