Help with making a copy of security on sd card
Im Needs step-by-step help to make a backup on sd card
thank you Marek
Hi John and others,
Simple question - When removing an SD card, is it safe to do it with power on?
I realize inserting the SD card must be with power on otherwise the system would try to boot from the SD.
Gary in Vancouver, BC
I suppose that there is a running bar during the writing precedure , but how to be sure about the END_OF_PROCEDURE so one can remove the micro_sd safely?
Any suggestion howto insert\remove the micro_sd by fat fingers in such tiny place ?
a plastic extension glued maybe ?
Could be possibile to cut a hole on the card back to put a fishing line to make removing simpler :-O
Phil
Maybe a PAUSE button will be ok to be pressed when one has pulled out the sd-card.
Would it not be more practical to make a copy directrly on a usb-memory as its plug is more easy to be accessed ?
Phil
