Possible bug with public facing GUI [fixed in v1.523]
Hi
I do not operate a kiwi but I am a frequent user and I've notice some odd behavior with the user GUI. I thought I'd offer the info to the forum here and let the developers run the issue down.
On my iPhone (IOS 15.4.1) and on my laptop's (Win7) Chrome & Firefox browsers I've been seeing the same issue: After going to the main KFS quad kiwi page at....
....I have experienced the following:
Selecting any of the four kiwis brings up a page that has a blank frequency box and even though I type in a frequency and hit return nothing happens. On Chrome and on IOS it reloads to display the "Play" arrow icon in the middle of the screen. The screen also does not populate my ID in the name/callsign box as it used to, probably based on a cookie.
The problem seems to come and go. The ham radio page at http://websdr1.kfsdr.com:8901/ seems to always function normally for me.
I don't want to send more emails to the KFS crew unless I can provide something useful.
Another user on a forum I frequent said this:
"I can confirm this happening to me on Firefox for Windows 99.0.1, Windows 10.
I noticed this morning that if I closed that browser tab and open it again a few minutes later (I went to get a coffee), it opened with 10 MHz WWV in use (as usual) and that may have been because someone in Switzerland had swooped in and grabbed the RX0 position. I don't know if that Swiss user had to do some extra gymnastics to get it to go to 10 MHz or not.
I don't use KFS that often (because it is quite popular) but by chance I used it last night (the first time in probably at least a month) and I noticed something similar. (I accessed the Omni from a saved bookmark, not from the "top level" menu you posted) and the first thing that I noticed is that the frequency input was not responding to changes. I ended up going somewhere else.
I have noticed similar weird behavior on certain Kiwis lately. (E.g., not responding to frequency changes.) It's random and not 100% repeatable. I have not made notes about which ones and when."
Short discussion is here: https://www.hfunderground.com/board/index.php?topic=96723.msg306943;boardseen#new
I also notice that if I get the blank frequency box I can just keep hitting refresh until I see the box properly populated.
Thanks to all of the kiwi operators out there. I hope this information is of some use to discovering the root cause.
Jim
Wow, there's something really strange about all 4 of those Kiwis. They're all running v1.509 which is a little old but should be okay. If you look at the javascript console (from the browser) on page load it thinks the variable "cfg.passbands" doesn't exist. That comes from the saved configuration file. Yet if you type "cfg.passbands" into the javascript console input field it appears just fine.
So I don't get it. One of them has been up 10 days, but another less than 24 hours. Maybe they should try updating to the latest software version and see what happens. You'll note there is no waterfall either because of this problem (because the javascript aborts before the page can completely load).
Also, it looks like they've modified the Kiwi index.html file directly to get their custom top banner. That's probably why they don't have auto updates turned on. Because an update would wipe out that change. A custom banner can be done with the admin page, webpage tab, "additional HTML" field. They may not realize this.
So if they've modified that file it makes me wonder what else they've done that might contribute to this problem.
Hi John,
I have been busy busy with WD 3.0 that I have barely looked at the 5 Kiwis at KFS: :8074/5/6 and 8083.
I have just instructed all of them to update to the latest Kiwi code, but I'll wait to hear from others if they are still experiencing problems.
Rob
Hi Rob,
Same problems using the same IOS on my iPhone 10 plus a new problem
When I try to type in a frequency it does not invoke a QWERTY keyboard. Instead it displays a mobile phone 10 digit keypad. I can enter numbers without a decimal point and there's no way to hit "ENTER" to load the numbers
Accessing via Chrome on the laptop is still presenting the same problems.
Thanks for looking into the issues.
Jim
On iOS the 10-digit keypad should show the word
doneat top right you can touch to submit the entry. I get this on my iPhone 6S running iOS 15. If you don't see this I'd like to know what iOS version you're running and a screenshot of what you're seeing. It's possible we have to revert to a different keypad for earlier iOS versions.It's yet-another-bug that iOS isn't using the 10-digit keypad that includes a decimal point. I'll fix that in the next release.
I don't know what's up with the KFS Kiwis. It looks like Rob updated them to v1.519. And that version runs fine on all the other Kiwis I tried. But the KFS Kiwis have this weird problem that looks like a Javascript timing bug of some sort. The KFS Kiwis still fail to load completely for me using Safari, Firefox or Chrome.
Update: Yeah, it's something about timing. While trying a bunch of times with Firefox, and flushing the cache each time, I got it to load exactly once.
Okay, problem understood. It's a race condition in the code. For some reason the network/timing conditions at KFS are slightly different and the race is frequently triggered. I was able to reproduce it by introducing some artificial timing delays. All I have to do to fix it is add some proper locking that should have been there in the first place.. 🙄
IOS 15.4.1
You are correct that I can use "Done" but there is no decimal point with that entry GUI. So I have to enter 4095 and then have to press the plus signs and steer to the right number of hertz. Before this I always had the Qwerty keyboard which was much more useful.
I have just started to upgrade all 5 of the KFS Kiwis from 519 to 522
The KFS site is connected to the Internet by a microwave link which is heavily used by WebSDR listeners as well as by one of the wsprdaeon.org backup servers. I am working both the reduce the network impact of the WD server and to increase the subscription bandwidth of the link.
On a perhaps related subject, in recent versions the Admin pages which I leave open continuously have started to report 'Server has closed connection' after some time. At KPH I have some 473 Kiwis and some 522 Kiwis and that 'Server has closed connection' page only appears on the 522 Kiwis. However the 473 Kiwis appear to silently terminate communications after some hours or days.
It would be helpful if those Admin pages were as stable as the listening sessions. But it is almost better to get the 'Server has closed connection' page, so I then know to refresh the page to see current status.
@rrobinet Okay, this all makes sense now. If that microwave link is inducing differential delay between the HTML load of openwebrx.js and the sound connection web socket then this issue will occur. It could easily do that because of limitations in how they buffer connection traffic (e.g. a large MTU). The race window is only a few hundred milliseconds wide. I don't honestly understand why we haven't seen this problem before given all the varied network connections Kiwis use.
Re "server has closed connection". I added this recently because previously you had no indication when the connection closed, either because the server restarted or the connection dropped for some reason. The result was that you could happily type into the admin page and it would look like it was accepting your input. But the reality was the page was "dead" and nothing was being transmitted to the server. This is a source of extreme confusion. At least for me.
@rrobinet Okay, v1.523 should fix the page load problem at KFS. Also, I added a reliability improvement to the admin server close code. I don't know if it will make any difference, but it might.
@teotwaki The decimal point in the 10-digit keypad for iOS is available again in v1.523
I have initiated a build of 523 on all 5 of the KFS servers
Thank you to all who helped to decipher and resolve the issues at KFS, especially the volunteer staff there! (I have donated in the past and will do so again.) It has been fascinating to see how the issues I identified have been discussed and before long to see normal operation restored.
I believe that prior to this I was able to use the IOS mobile interface and be able to adjust the receive bandwidth (green passband symbol) in order to eliminate close in signals. Now I cannot adjust it. Was that a change in the mobile user interface software a while back?
Jim
Yeah, there's something up with that. I'll look at it.
In the next release I think this is fixed.
Necromancing my old thread. KFS has been under new management and the web pages were reworked but have various small flaws. There is no longer any “contact us” link that I can find since Craig passed away
The SE kiwi may have an issue. As far as I can tell it only shows up when I access with an iPhone-16 running 18.6.2
The audio is always distorted no matter the frequency or demodulation mode selected. All other kiwis perform normally as do the ham SDRs.
suggestions?
thanks!
Jim
I fixed http://rx.kiwisdr.com/?s=KFS so that the four KFS entries now correspond to the Kiwi with antennas: Omni, NW, SW and SE. Previously all four pointed to the Omni Kiwi.
I was able to get the SE Kiwi to work with my iPhone 10 (X) running iOS 16.7 (older). Sounded fine.
For distorted audio: Make sure the noise blanker and/or filter are not enabled (control panel audio tab, top line), as they are re-enabled if they had been set during the prior connection to a particular Kiwi. Maybe I should popup a panel during connection if they are enabled to remind one of this situation.
Sorry for the late response. I was out of the US for a little while.
I'm glad you caught the bug where all of the kiwis defaulted to the Omni. I had forgotten to mention that.
The distorted audio is gone. If I was the culprit I will know to check the blanker and filter before commenting here. 😯.
New issue. There is no longer a decimal point to use for frequency entry. That button was replaced with one for +*# . Currently frequency can only be entered to the lowest kilohertz. See picture
Thanks for hearing me out and explaining what is going on.
Jim
What iPhone model, iOS version and browser? I only have an old iPhone 10 running iOS 16, but my keypad has the "." not "+*#".
We went through this debacle of Apple changing the HTML-to-keypad mappings some time ago. I swear, if they've changed it again...
Found an iPhone 13. Keypad shows the decimal point in iOS 17.6.1 and 18.7.1 (the phone hadn't been updated in a while). Also checked with the KFS SE site (running v1.819). All seems ok. So I don't know what to think.
Anyone else with this issue?
Hello jks!
My iPhone 16 pro is on 18.7.1 which is marked as up to date. Safari browser. It is possible to jump to ios 26. I also tried the Utah kiwi frequency entry with the same result.
I'm going to have to find an iPhone 16 to test with. But early indications are that indeed Apple changed things starting with iPhone 16 and now ignores requests to get a decimal keypad. At least the way the Kiwi code currently does it.
As a workaround, can you long-press the
+*#key to get the alphanumeric keypad and enter the decimal point?Found an iPhone 16 running iOS 18.7.1 But it works! I get the decimal point in the keypad.
What do other browsers do? What happens if you go to: settings, apps, safari, clear cache and website data, and just clear it for today ONLY. Does that change anything?
Anyone else have this issue with an iPhone 16? Working or not? Thanks
I'm on iOS 26 and get the dot using both safari and firefox.
my guess is a setting in the phone keyboard could be the culprit.
For what it's worth, an AI-search claims there is no iOS setting that influences this '.' versus '+*#' appearance in the keypad.
Over the last week I experimented with versions of clearing website data in Safari. Last hour or today or today & yesterday. No effect. I checked General-Language-Region and it was set correctly for the US. I tried switching the number format to work without commas but no effect.
I loaded Firefox and the kiwi keyboard does have the decimal point. So using that browser is my temporary workaround
Updated to iOS18.7.2 with no improvements. Am a bit reluctant to switch to iOS 26 just yet.
I googled the “numeric key keyboard no decimal” topic and it’s a very common discussion over the years. Found this
“Website Input Field Coding (HTML5):
Cause: The numeric keypad that appears is often triggered by HTML input types like <input type="number">. If the website developer hasn't implemented specific attributes (like pattern="[0-9]*" for the pure numeric keypad or handling for decimal input modes), the dot/comma might be unavailable or incompatible with their site's logic. This is a common issue with specific banking or e-commerce sites.”
I know almost zero about HTML but also found this from the Google AI mode:
Check the Website's Input Type: The input field you are tapping on is likely configured by the website developer to accept phone numbers (using HTML
type="tel"), which triggers the phone keypad (digits and+*#). This is a website design choice, and the user has little control over it directly.Recommended HTML Solution
The modern and most reliable way to display a numeric keyboard that includes a decimal point is to use the
inputmodeattribute in conjunction withtype="text"(or sometimestype="number"):html
Use code with caution.
type="text": This ensures maximum compatibility across different browsers and avoids some of the built-in validation issues thattype="number"can have.inputmode="decimal": This attribute explicitly tells mobile browsers to display a numeric keypad that includes the decimal separator (either a dot or a comma, depending on the user's regional settings).Why the The +*# keypad is triggered by the following HTML:
html
or
html
The
type="tel"input is specifically designed for phone numbers and, by design, lacks a period/comma key, as phone numbers do not typically use them. If the website is currently using either of these, changing it to the recommended solution above will solve the problem.Summary of HTML Changes
Current HTML (Shows
+*#)Recommended HTML (Shows
.)<input type="tel" ...><input type="text" inputmode="decimal" ...><input type="text" pattern="[0-9]*" ...><input type="text" inputmode="decimal" ...>This change ensures that users are presented with the appropriate keyboard for entering decimal numbers, improving the user experience on iOS devices.
