I keep getting a "connection refused" message in the browser [software install issue]
I may have screwed up something but here's what I did last.
I disconnected the ethernet cable, put in the micro SD card, and booted the Kiwi.
The 4 blue lights were active for about a minute or so.
When they stopped, I took the card out, hooked up the ethernet card, and rebooted.
I have verified the local address with fing.
This computer has the firewall turned off.
Our router's firewall is configured to allow all traffic.
When I enter the ip:8073, I get a message saying that the connection is refused.
What's next? Any help will definitely be appreciated.
Thanks,
Bill
Thanks,
Bill
I did try to power it up with the flash card in and the internet connected.
With the internet disconnected, I did the same thing, and the back and forth pattern (blue lights) went for about 4 minutes.
I actually powered down before removing the card, then rebooted.
It's a new unit with the BB and Kiwi, and I did initially power up with the card in place.
I think that's most of it.
THX again!
However, the answer is definitely appreciated. Maybe that could be an option. :-)
1) unplugged everything from the BB
2) re-installed the flash card
3) powered up via the DC port
4) the 4 blue LEDs did a nice show, including back and forth for a while, then all 4 on at the same time
5) the 4 blue LEDs shut off, and so did the power LED
6) I removed the power cord, and then pulled the micro SD chip
7) I connected the ethernet cable and powered up.
8) there seemed to be a lot of ethernet activity (green LED) AND the two outside blue LEDs continue to flash randomly
9) tried to go online through this browser and got the same error message.
OK, I must be temporarily brain dead.
I went to the ipad and checked FING again... it has assigned a new IP.
I can NOW CONNECT through the correct IP.
Sheesh.
Thank you so much for helping me through this. I am going to love it with my PA0RDT mini-whip, I can tell already!
Best,
bill
I am astounded! You can't believe what I'm getting here during daylight hours. Amazing.
We have a Lennox HVAC system here and the VS drives for the inductor, the blower, and the heat exchanger cause a lot of problems (at least they did with my Airspy on a Linux PC). I have been in discussions with the contractor and with Lennox engineering and they are supposed to be supplying an engineered filtering system for the RFI. I expect to hear from them this week.
I have a mini whip antenna about 35 feet above ground level. I'm about 75 feet from some 440 V power lines but they don't seem to be a problem. This antenna really works well if you can get it away from RFI, buildings, etc.
About the reflashing procedure: I have learned\red of the LAN cable disconnection here for the first time.
Is it mandatory ?
Just as a reminder for the worst_NOGO_case..... we say here "touch_the_steel"&pray
73
Phil
I would like to list 2 slots on my KIWI on sdr.hu. I think I have put it all the pertinent info but I am a bit confused about the domain name/ip address setting.
It seems that the ip of my modem should work. Is that correct? If so, am I taking any security risks with my LAN?
I have the key from sdr.hu so I think this is the last thing to sort out.
Thanks,
bill
