NAT rule on router forgotten
Hi all,
I have a KiwiSDR 1. Every time I switch it off and then on, its blocked by the router. If I then select 'Auto-add NAT rule' to OFF and then ON again, everything is okay. Why does it not remember the setting?
This did not fail until about 6 months ago. Is it a known issue of the KiWiSDR?
Kind regards, Marco.
  • You might be better off adding the rule manually on your router.
    SV1XV
  • Could it be that the kiwis IP adress changes after it was switched off?
    SV1XV
