NAT rule on router forgotten
Hi all,
I have a KiwiSDR 1. Every time I switch it off and then on, its blocked by the router. If I then select 'Auto-add NAT rule' to OFF and then ON again, everything is okay. Why does it not remember the setting?
This did not fail until about 6 months ago. Is it a known issue of the KiWiSDR?
Kind regards, Marco.
You might be better off adding the rule manually on your router.
Could it be that the kiwis IP adress changes after it was switched off?
