Not showing on map and not updating [fixed]
edited November 2024 in Problems Now Fixed
Hi. I registered my KiWiSDR a couple of days ago, and although it says that registration is successful, it's not appearing in the public listing or the map. When I check the version, I see I'm on 1.698, so perhaps the update is also not working. Clicking "Check now" in the Update page causes a message "Filesystem is FULL", so perhaps that's the problem although I don't know why it should be.
The response from a 'df' command in the console is as follows.
root@kiwisdr:~/Beagle_SDR_GPS# df
Filesystem      Size  Used Avail Use% Mounted on
udev             10M     0   10M   0% /dev
tmpfs            99M  8.3M   91M   9% /run
/dev/mmcblk0p1  3.6G  3.3G   29M 100% /
tmpfs           247M     0  247M   0% /dev/shm
tmpfs           5.0M     0  5.0M   0% /run/lock
tmpfs           247M     0  247M   0% /sys/fs/cgroup
Is there some way to resolve this.
Thanks
Steve
Also from the log :-
Fri Nov 22 21:50:18 1d:13:03:02.835 ....      L UPDATE: force update check by admin
Fri Nov 22 21:50:18 1d:13:03:02.839 ....      L UPDATE: checking for updates
Fri Nov 22 21:50:18 1d:13:03:03.104 ....      L UPDATE: Filesystem is FULL!
Fri Nov 22 21:50:18 1d:13:03:03.108 ....        task _update_task:P3:T004((250.000 msec) TaskSleep) exited by returning
Fri Nov 22 21:51:15 1d:13:03:59.980 .... [02]   CONSOLE: open connection
Fri Nov 22 21:56:07 1d:13:08:51.414 ....        _reg_public: sp == NULL?
URL: vk3cmz.ddns.net:8074
  • Please email your Kiwi admin password to support@kiwisdr.com (set a temp pwd if you like)
