Not showing on map and not updating [fixed]
Hi. I registered my KiWiSDR a couple of days ago, and although it says that registration is successful, it's not appearing in the public listing or the map. When I check the version, I see I'm on 1.698, so perhaps the update is also not working. Clicking "Check now" in the Update page causes a message "Filesystem is FULL", so perhaps that's the problem although I don't know why it should be.
The response from a 'df' command in the console is as follows.
root@kiwisdr:~/Beagle_SDR_GPS# df Filesystem Size Used Avail Use% Mounted on udev 10M 0 10M 0% /dev tmpfs 99M 8.3M 91M 9% /run /dev/mmcblk0p1 3.6G 3.3G 29M 100% / tmpfs 247M 0 247M 0% /dev/shm tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs 247M 0 247M 0% /sys/fs/cgroup root@kiwisdr:~/Beagle_SDR_GPS#
Is there some way to resolve this.
Steve
Also from the log :-
Fri Nov 22 21:50:18 1d:13:03:02.835 .... L UPDATE: force update check by admin Fri Nov 22 21:50:18 1d:13:03:02.839 .... L UPDATE: checking for updates Fri Nov 22 21:50:18 1d:13:03:03.104 .... L UPDATE: Filesystem is FULL! Fri Nov 22 21:50:18 1d:13:03:03.108 .... task _update_task:P3:T004((250.000 msec) TaskSleep) exited by returning Fri Nov 22 21:51:15 1d:13:03:59.980 .... [02] CONSOLE: open connection Fri Nov 22 21:56:07 1d:13:08:51.414 .... _reg_public: sp == NULL?
URL: vk3cmz.ddns.net:8074
Please email your Kiwi admin password to support@kiwisdr.com (set a temp pwd if you like)
