Stuck on v1.699?
While doing 'Check on software update' I receive the following response (after quite long delay):
Installed version: v1.699, built Aug 25 2024 02:54:52
Git clone damaged!
Something wrong with the download site?
Regards, Per
Git clone damaged!
Regards, Per
Are you running Debian 8? (Debian version shown on the admin status tab)
Debian 8.5
Okay, I have to write a long post about this situation as it has now become a huge problem it seems.
I then assume that this is a Debian 8 problem, I start upgrading our Kiwis over the weekend, it is already long overdue.
Per
Okay, but if you've made extensive changes to your dx labels make sure you save them first using the JSON/CSV file save function on the admin dx tab.
And if you've made extensive admin customizations that would otherwise be difficult to re-enter by hand then make sure you make an sd card backup using the admin backup tab. Because re-flashing using the Debian 11 image destroys all of your configuration. I can tell you how to move the configuration files from the sd card back to your new Debian 11 system afterwards.
Thank You for the warning about changes to dx labels, I will take care of the files. I will follow the steps in https://forum.kiwisdr.com/index.php?p=/discussion/3096/debian-11-upgrade-for-kiwis-using-beaglebone-green-black/p1 so I assume there should be quite straight forward. And in the worst case there would not be to bad to configure from scratch.
Per
Yes, those instructions should be fine.
I am sorry about this. I am editing this large post now. It is unfortunately completely unknown why Debian 8 is failing with Github.com. And in only certain situations (e.g. I can do it from here in NZ all day long and not have an issue).
But for security reasons updating from D8 to D11 is a good idea anyway.
I just had to update those instructions a little bit because of some changes to command alias and directory names in the most recent releases.
For example, the instructions now say:
Note the "or" alternatives below because some command aliases and directories were renamed recently.
mosd1ormsd1p1Many thanks John.
Two KiwiSDR upgraded to Debian 11 without any problems and then updated to v1.701 by themself. One more KiwiSDR to go, but this is a 6 hour round-trip so it will be done i due time.
73 de LA9XKA - Per
