GPS Antenna for multiple kiwis
I now have 2 kiwis. Is the GPS antenna an active antenna? I'm wondering if I can just split one antenna to both kiwis?
  • The antenna is active. There are passive and active GPS splitters, mine work well with an active one.
    With a passive splitter, the signal might be too low. And you potentially need to take care to not backfeed the 5V bias to the other kiwi, although I don't know if that would be a problem.
  • Could probably bias it with one kiwi and use an AC-coupled splitter to the other -- however it might just be easier to deploy two GPS antennas. They are pretty small...
  • Bonjour,
    Si ce n'est pas trop tard, j'utilise un répartiteur 2 voies pour télévision câblée marque Triax
    Trouvé en grande surface de bricolage avec les paraboles.
    73 rené F6bir
