There will be proxy service downtime/restarts as the crashing problem is debugged.
help finding bug: name/callsign field
I need some help finding a possible bug.
Seems to me the majority of connections to a Kiwi now appear without the name from the "Your name or callsign" field at the upper left appearing on the status panel at the lower right.
Now instead of seeing the usual
RX0: "ZL/KF6VO" (Tauranga, New Zealand) ...
you'll just get:
RX0: (Tauranga, New Zealand) ...
But I can't duplicate the problem here. With the name field set will you try connecting to kiwisdr.com:8073 and let me know what you see? Also let me know if the location field, the one inside (), incorrectly says "unknown location".
Thank you.
Changes done in the callsign field also appear correctly.
As for the location, with Firefox I have "unknown location" and with Chrome I have "Luxembourg".
The reason, at least for my setup is that I have an addon in Firefox called uBlock Origin.
When switching uBlock off, the location appears correctly.
LX1DQ, Frank
Ublock Origin is open source:
https://github.com/gorhill/uBlock
