My problem may be too out-of date, as I didn't use my KiwiSDR for more than a year, and only now realized it's still running v.1.461! However, it's stuck there and I can't update it. Check version on the Admin interface says "Installed version: v1.461, built Jul 17 2021 16:24:27 / Available version: v1.601". I've tried to run up over ssh, as well as update_fix over the console on Admin interface - on all cases there's an error saying:
In file included from extensions/HFDL/dumphfdl/src/util.h:6: extensions/HFDL/dumphfdl/src/pthr.h:8:14: fatal error: 'glib.h' file not found
Any advice how can I update it, besides reflasihng the BBB with the latest image?
Unfortunately you're going to need to re-flash using the Debian 10 image.
Because a Debian package needs to be installed to get glib.h for the HFDL extension that was introduced in v1.472 And with Debian 8 it is no longer possible to install packages due to changes at debian.org ...
@jks Thank you for the quick response - that was what I've guessed too... Need to find the good SD cards and some time over the weekend now... Thanks again and kind regards == Mac Ha
@jks I've got a SD card and trying to upgrade, done the backup, however verifying the backup got me this (sorry, don't know how to embed code in the posts?..):
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
mmcblk0boot0 179:8 0 1M 1 disk
mmcblk0boot1 179:16 0 1M 1 disk
mmcblk0 179:0 0 1.8G 0 disk
`-mmcblk0p1 179:1 0 1.8G 0 part /
mmcblk1 179:24 0 59.7G 0 disk
`-mmcblk1p1 179:25 0 1.7G 0 part /media/sd_boot
I see the different sizes then in your instructions - would that impact the upgrade?
Also running the diff commands got
-bash: colordiff: command not found
I'm pausing the upgrade, in meantime, waiting for your reply.
The instructions say "the output should be similar to the following". Your output is similar. The important part is that you have both mmcblk0 and mmcblk1 present.
colordiff not being found is a symptom of the Debian package problem. Try /usr/bin/diff instead.
I have modified the instructions to make these issues more clear.
One of my two Kiwi's stopped worked for a while ago. It was impossible to access it, even locally and two of the blue LEDs blinked in sequence, suggesting that my Kiwi's file system had gone corrupt. Possibly because of a network glitch during an automatic update.
Anyway, I had and still have a backup stored on a SD Card, so I re-flashed the Kiwi and that worked fine. I can now access it again, but with software v1.451 and I get some errors in the Admin/Log screen:
hu May 18 12:37:37 01:23:41.695 .... L TIMEZONE: lat/lon from admin public config: (59.689999, 10.340000)
Thu May 18 12:37:37 01:23:42.077 .... L TIMEZONE: timezonedb.com curl error
Thu May 18 12:37:43 01:23:47.709 .... E09 UNKNOWN W16
Thu May 18 12:37:43 01:23:47.710 .... E21 UNKNOWN W16
Thu May 18 12:37:55 01:23:59.822 .... E09 UNKNOWN W17
Thu May 18 12:37:55 01:23:59.823 .... E21 UNKNOWN W17
Thu May 18 12:37:57 01:24:01.597 .... E09 UNKNOWN W19
Thu May 18 12:37:57 01:24:01.598 .... E21 UNKNOWN W19
Thu May 18 12:37:59 01:24:03.615 .... E21 UNKNOWN W16
Thu May 18 12:37:59 01:24:03.867 .... E09 UNKNOWN W16
Thu May 18 12:38:13 01:24:17.740 .... E09 UNKNOWN W16
Thu May 18 12:38:13 01:24:17.740 .... E21 UNKNOWN W16
Thu May 18 12:38:25 01:24:29.605 .... E21 UNKNOWN W18
Thu May 18 12:38:25 01:24:29.857 .... E09 UNKNOWN W18
Thu May 18 12:38:27 01:24:31.619 .... E09 UNKNOWN W20
Thu May 18 12:38:27 01:24:31.619 .... E21 UNKNOWN W20
Thu May 18 12:38:29 01:24:33.640 .... E09 UNKNOWN W16
Thu May 18 12:38:29 01:24:33.640 .... E21 UNKNOWN W16
I think the errors above will be gone with a successful update, but the problem now is to get it updated to v.1.601. The automatic or forced update gives a few errors (see the log), so I tried going to the Console tab and issued the command "update_fix". I have tried "update_fix"+ server restart four times, but there are still some (the same) errors and Kiwi seems stuck on v.1.451 because of that.
Any suggestion / tips on how to fix this and get it upgraded will be very much appreciated.
I also have TeamViewer nstalled here so remote support is possible too. Eventually, I can be contacted on mail: la6lu.no(#)gmail.com for Teamviewer appointment.
You'll need to update to Debian 10. See the kiwisdr.com home page section "Debian 8 no longer supported". It includes instructions for preserving your configuration changes if that is important. Updating is simplified if you don't care about preserving the config changes.
The "Enn UNKNOWN Wnn" messages are Galileo sats sending unexpected subframes. In that old version of the software that error message hadn't been commented out yet.
Many thanks, I am almost there and the most critical part is done, but I have problems restoring original config files. (see below).
As reference, here is part of what the instructions says:
Mount the sd card, copy the configuration files, verify the files, unmount the card.
mosd0
cd /media/sd_boot/root/kiwi.config
Copy the required configuration files.
cp admin.json kiwi.json dx.json ~/kiwi.config
diff admin.json ~/kiwi.config
diff kiwi.json ~/kiwi.config
diff dx.json ~/kiwi.config
[New] Copy the optional files. Ignore any error about a particular file being missing.
My mmc command, gives:
root@kiwisdr:~# mmc
mmcblk1 179:0 0 3.7G 0 disk
└─mmcblk1p1 179:1 0 3.7G 0 part /
mmcblk1boot0 179:8 0 2M 1 disk
mmcblk1boot1 179:16 0 2M 1 disk
I have my backup sd-card with the original config files card inserted and locked.
root@kiwisdr:~# mosd0
mount: /media/sd_boot: special device /dev/mmcblk0p1 does not exist.
root@kiwisdr:~# cd /media/sd_boot/root/kiwi.config
bash: cd: /media/sd_boot/root/kiwi.config: No such file or directory
root@kiwisdr:~#
Looks like the inserted sd-card is not found. It should be ok, as I used it for the initial restore to recover when my Kiwi's file system was corrupted earlier. I got it back working with Debian 8 and KIwi v1.451 with this sd-card.
If I try mosd1 instead of mosd0, I get this with mmc:
root@kiwisdr:~# mmc
└─mmcblk1p1 179:1 0 3.7G 0 part /media/sd_boot
root@kiwisdr:~#
Then:
Try pushing the sd card in until it clicks out of the socket. Wait a few seconds. Then click it in again and see if mmc finds it. I've found that sometimes you have to do this before the card is recognized.
Also, do a dmesg command and see if at the end of all the messages there are any errors related to detecting the card.
Definitely do not do mosd1 because you're just mounting the active filesystem on /media which will cause all sorts of confusion.
It helped re-trying pushing in the cd-card, until i saw withdmesgthat the card was accepted.
The copy, diff etc. went just fine and the kiwi is up an running with everyhting I could wish for. Will do some small changes in my configuration now and then (re-)publish the Kiwi at rx.kiwisdr.com later this evening.
the tally is done to 6%.... I have been following up on CONUS systems that have low noise/spurious with an additional prod.
I have contacted a few US OPs directly offering to help. They were having troubles, helped them through it and we're now down to < 5%
After 4 or 5 times... after an hour or so I end up with a line like this -- and many more before it...
and nothing more...
somewhere about there it dies.... and I try again...
v1.462: MANUAL INTERVENTION REQUIRED to receive future updates - Page 4
https://forum.kiwisdr.com/index.php?p=/discussion/comment/13658#Comment_13658I am doing update_fix on two remote Kiwi's -- I'll keep you posted...
If that doesn't work I can tell you how to do a fresh clone from Github.
Also, do a
df .
anywhere in /root and make sure there is at least 600 MB of free filesystem space before/during building.My problem may be too out-of date, as I didn't use my KiwiSDR for more than a year, and only now realized it's still running v.1.461! However, it's stuck there and I can't update it. Check version on the Admin interface says "Installed version: v1.461, built Jul 17 2021 16:24:27 / Available version: v1.601". I've tried to run up over ssh, as well as update_fix over the console on Admin interface - on all cases there's an error saying:
Thank you == Mac Ha
Thank you and kind regards == Mac Ha
mmcblk0
andmmcblk1
present.colordiff
not being found is a symptom of the Debian package problem. Try/usr/bin/diff
instead.I have modified the instructions to make these issues more clear.
update_fix
"+ server restart four times, but there are still some (the same) errors and Kiwi seems stuck on v.1.451 because of that.I have made available on dropbox two files.
Thanks...
Regards
Geir Laastad, LA6LU
mosd0
root@kiwisdr:~# mmc
root@kiwisdr:~#
root@kiwisdr:~# mmc
root@kiwisdr:~#
Then:
root@kiwisdr:/media/sd_boot/root/kiwi.config#
root@kiwisdr:/media/sd_boot/root/kiwi.config# cp admin.json kiwi.json dx.json ~/kiwi.config
cp: 'admin.json' and '/root/kiwi.config/admin.json' are the same file
cp: 'kiwi.json' and '/root/kiwi.config/kiwi.json' are the same file
cp: 'dx.json' and '/root/kiwi.config/dx.json' are the same file
Hmm, same files? Yes, because I have probably not accessed the backup files.
So mosd1 was probably wrong doing, but worth testing.
I have paused at this stage for now .
mmc
finds it. I've found that sometimes you have to do this before the card is recognized.Also, do a
dmesg
command and see if at the end of all the messages there are any errors related to detecting the card.Definitely do not do
mosd1
because you're just mounting the active filesystem on/media
which will cause all sorts of confusion.Thanks again John,
dmesg
that the card was accepted.The copy, diff etc. went just fine and the kiwi is up an running with everyhting I could wish for. Will do some small changes in my configuration now and then (re-)publish the Kiwi at rx.kiwisdr.com later this evening.
Thanks again for you kind help. :)
73 de Geir, LA6LU
Thanks. I finally updated, My update required almost 2 hours on a Think Pad --- so have lots of patience.
