kiwirecorder.py using mode=IQ and --s-meter
@jks I would like to record the IQ wav file and the RSSI at the same time with the timestamp ( --ts).
It seems that as soon as I add "--S-meter=0", "--ts" the IQ wav file is not saved.
So:
python kiwirecorder.py -k 10 -s jnb.twrmon.net -p 8073 -f 1458 -m iq --tlimit=12
work fine - get the IQ Wav file and the long list of RSSI readings.
BUT when I add on the end --s-meter =0
python kiwirecorder.py -k 10 -s jnb.twrmon.net -p 8073 -f 1458 -m iq --tlimit=12 --s-meter=0 --sdt-sec=3
I get no IQ wav file.
Thanks for any help.
When I add --snd
python kiwirecorder.py -k 10 -s jnb.twrmon.net -p 8073 -f 1458 -m iq --tlimit=12 --s-meter=0 --sdt-sec=3 --snd
then, I do get a wav file but is this an audio wav file or a IQ wav file?
I'll get to this when I can. Things are stupidly busy right now..
Thank you, much appreciated.
I do need clarity on this and to be sure I am recording an IQ WAV file.
I have done a lot with kiwirecorder and I/Q wav files so I know that works. I have just not used your exact cli string
I used
./kiwirecorder.py -k 5 -s $1 -p 8073 -f $2 -m iq -L 300 -H 3600 --ncomp --tlimit=$3
with $1 $2 $3 added on cli
Just getting to this now. Yes, adding
--snd
is what you want.The file will be real (1-ch mono) or IQ (2-ch stereo) depending on the
-m <mode>
setting. Modesiq drm sas
orqam
will result in a 2-ch stereo file. Remember that the mode is reflected in the sound filename, e.g. "20230728T191504Z_10000000_iq.wav"Thank you for confirming this.
I just tried what @WA2ZKD gave:
And it does work fine.
But when I added --s-meter=0 with --sdt-sec=5 there was no iq wav file recorded but @jks has confirmed that I must --snd and the wav file recorded is a IQ wav file. QED. 🙂
PS.. Still working on MW AM Modulation as time permits, so want to record the RSSI along with the IQ wav file.
python3.7 kiwirecorder.py -k 5 -s xxx.net -p 8073 -f yyyy -m iq -H 5000 --ncomp --tlimit=120 --s-meter=0 --sdt-sec=10 --ts --snd
see this for your AM demod
GitHub - ha7ilm/csdr: A simple DSP library and command-line tool for Software Defined Radio.
https://github.com/ha7ilm/csdr
