Messed up my listing on kiwisdr.com/public
I changed the name of my Kiwi SDR and have messed up the receiver listing on kiwisdr.com/public
Search: g8ure (and you will see what I mean.)
I have re-started the Kiwi also made not public then made public again.
I note the details on the kiwisdr.com Map is correct.
Have I messed up my details on the website data base ?
73
Jonathan
G8URE
Big thanks to the folks who designed the hardware and continue maintaining the firmware :-)
Looks like I don't handle escaping the HTML comment sequence (dash, dash, greater than) properly. Workaround would be for you to use
=>or==>instead.p.s. Holy cow that beverage has good VLF/LF S/N..
Thank you...
I removed the ''-->'' changing the name to ''Beverage - North''. This fixed the problem :-)
I run a beverage and a dipole SDR here so people can compare the two.
Sometimes I run a third SDR on a second beverage at 90 deg. This shows the directivity.
73
Jonathan
G8URE
