Latest software appears to FORCE software update v.559
I have sdr_hw=KiwiSDR v1.557; this morning I checked the availability of new software via the admin console. It showed a new version 1.559 and after that directly -- without my intervention -- started to update.
Wed Sep 7 08:10:34 00:00:38.988 ........ L UPDATE: version changed, current 1.557, new 1.559 Wed Sep 7 08:10:34 00:00:38.992 ........ L UPDATE: building new version..
It looks as if the function Automatically check for software updates? YesNo (in my case YES), does not work as I always have to do this manually
but the function Automatically install software updates? (it is on YES, although I keep it as a standard on NO ??), does work
How is that ?
Erwin
PE3ES / F4VTQ
No. I just checked and everything is working fine. An automatic update will not occur unless both of the switches on the update tab (
checkandinstall) are set to YES.If
checkalone is set to YES then a message will appear in the log if a new version is available. But the new software version will not be installed. Both switches must be set to YES.
