static ip does not change
                    HI All , I have just received the KIWI_SDR nr 1680 and switched it on.
The Cape has done all the manoevrues and now it plays on the v 1.51.
The receiver works fine in local mode.
I went in the admin page and wanted to change from DHCP mode to static, all 3 fields are green\OK,
then pushed the STATIC-green field and a red REBOOT_required + a blue Beagle_Reboot push button appeared.
I have done already two times but the IP remains on its previous state.
I have also switched OFF , but still nothing.
Where am I wrong ?
Phil IC8POF
Where am I wrong ?
Phil IC8POF
sorry for bothering.
73
Phil IC8POF
Yes some explaining points should be clearer HI HI.
I am using a chinese made psu variable voltage and rated at 3Amp but sold by EU distributor REICHELT.DE
Goobay EcoFriendly NTS3000EUP, it is mild warm and even if I measured 400Hz spikes on the oscilloscope
there is no noticeable noise now on 160mt
Now have to find why even if the 8073 firewall service is opened why it does snot accept calls from outside eheheh
73
Phil_IC8POF
