@rrobinetupdate_fix is a script in the ~/Beagle_SDR_GPS directory. So you have to cd there before typing it will find it. Use the cdp alias as a quick way to do that.
Before running the script, try some of commands from the above post:
@rrobinet Some more questions: Does the admin page load anything at all? Like just the tabs at the top of the page? Or do you get a completely blank screen? Or does your browser give you a connection error?
root@kiwisdr:~/Beagle_SDR_GPS# m git
make: Warning: File '../build/obj/ext_init.d' has modification time 764274 s in the future
git clean -fd
git checkout .
git pull -v git://github.com/jks-prv/Beagle_SDR_GPS.git
fatal: unable to connect to github.com:
github.com[0: 140.82.114.4]: errno=Network is unreachable
Makefile:1171: recipe for target 'git' failed
make: *** [git] Error 1
@WB8LBZ I just don't get it. You are able to connect to the Kiwi from a machine on the same 192.168.0.xxx local network. That machine is able to connect to sites on the Internet without problems. But the Kiwi has no routing outside of 192.168.0.xxx at all!
What URL are you typing into the browser to get to the Kiwi? Its ip address? kiwisdr.local:8073?
What output do you get from the commands:
ip
route
Are you doing ANYTHING non-standard, e.g. wifi anywhere. And this worked fine running the version prior to v1.462? Any idea when the last time an update happened? Do you have automatic updates turned on or is it off and you choose to do updates manually?
Ah! I'm glad I checked in to the Forum, because I was noticing some errors regarding automatic updates. I concur with the idea of "Binary Only" updates... MUCH easier for end users. :)
So far, so good... "update_fix" is running on my unit. Fingers crossed!!
EDIT: It works! :) THANK YOU!
"Installed version: v1.465, built Sep 20 2021 03:18:23
@WB8LBZ Well, the fact that the auto update was finally able to pickup v1.465 means something about the networking got sorted out behind the scenes. I'm inclined to blame the ISP (having been one myself in the distant past).
@WB8LBZ Sorry, misinterpreted your comment. Have you ever tried rebooting the Beagle to see if it clears the "network is unreachable" problem? Click the blue "Beagle reboot" button on the admin page, control tab. It will take about a minute before the admin page will respond again.
Well that is a bit strange, like putting a wheel back on a car without an obvious cause for it to have come off in the first place, still it's better running with the wheel on, and we can review further down the road now.
Apologies for the trouble. Please follow these directions. First, when admin page is shown, open browser "console" window from browser menu. Example for Firefox shown below. I show Kiwi user connection below since I cannot access your admin page. But this procedure works only on the admin page.
Second, type at bottom of console window where green arrow points: ext_send('SET force_check=1 force_build=1') This will start software rebuild to current version. Takes 30 to 60 minutes.
"So my guess is that the changes to make the config files more readable has not properly handled all the weird Unicode that some people insist on adding to their customizations." - Is this why all my DX tags for Radio Martí turned into Radio MartC- instead?
@rrobinet
update_fix
is a script in the ~/Beagle_SDR_GPS directory. So you have to cd there before typing it will find it. Use thecdp
alias as a quick way to do that.Before running the script, try some of commands from the above post:
gst
gurl
head -2 Makefile
Can you make a user connection to this Kiwi?
Thanks for the quick replies.
I found your manual update instruction on the Quick Start guide and 'cdp;up' worked perfectly
Okay, good.
up
andupdate_fix
do the same job essentially.up
is designed to be run from an ssh session andupdate_fix
from the admin console tab.after I gave it the gclone Beagle_SDR_GPS
73, Larry WB8LBZ
El Paso, TX
@WB8LBZ Okay, please try:
cd
mv B.old Beagle_SDR_GPS
touch /root/kiwi.config/opt.git_no_https
cdp
m git
Stop if the above command gives any sort of error.
update_fix
I got:
73, Larry WB8LBZ
El Paso, TX
@WB8LBZ Well, I'm almost out of ideas. You've got some pretty serious networking problems that are not necessarily a Kiwi issue. What happens if you:
cat /etc/resolv.conf
tr 1.1.1.1
tr google.com
tr github.com
Here is what I got back:
root@kiwisdr:~/Beagle_SDR_GPS# cat /etc/resolv.conf
domain elp.rr.com
search elp.rr.com
nameserver 192.168.0.1
nameserver 1.1.1.1
root@kiwisdr:~/Beagle_SDR_GPS# tr 1.1.1.1
traceroute to 1.1.1.1 (1.1.1.1), 30 hops max, 60 byte packets
connect: Network is unreachable
root@kiwisdr:~/Beagle_SDR_GPS# tr google.com
traceroute to google.com (172.217.1.238), 30 hops max, 60 byte packets
root@kiwisdr:~/Beagle_SDR_GPS# tr github.com
traceroute to github.com (140.82.112.4), 30 hops max, 60 byte packets
73, Larry WB8LBZ
El Paso, TX
Larry could you show the result of "iptables -S"
Also "route"
kiwisdr.local:8073
?What output do you get from the commands:
ip
route
Please continue the discussion about Ulli's problems in the new thread "v1.462: update problems" and not here.
Thank you.
Running most current version"
I'm back after playing on a weekend Ham Radio contest.
The question from Powernumpty, and jks
From the console:
The Kiwi is plugged into a switch on the network like my surfing computer. Looks like the build is up to v1.465 now.
73, Larry WB8LBZ
El Paso, TX
The route looks surprisingly light (E.G. no default gateway).
I'll let the main man give a sensible answer while I sit here wondering 1. how it got like that 2. still managed to update.
No, I'm still on v1.461 I want to get to v1.465 as mentioned by N1NKM.
73, Larry WB8LBZ
El Paso, TX
You could try
"route add default gw 192.168.0.1 eth0"
Assuming your router is 192.168.0.1
Once it does try these again please:
route
tr 1.1.1.1
tr google.com
tr github.com
It has been off for since Friday afternoon but I'll try these.
Larry
@jks , here is what I got back,
root@kiwisdr:~/Beagle_SDR_GPS# route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
192.168.0.0 * 255.255.255.0 U 0 0 0 eth0
192.168.7.0 * 255.255.255.252 U 0 0 0 usb0
domain elp.rr.com
search elp.rr.com
nameserver 1.1.1.1
traceroute to google.com (142.251.46.142), 30 hops max, 60 byte packets
73, Larry WB8LBZ
El Paso, TX
@WB8LBZ And this is after a reboot? What do you get if you do
uptime
? Also, please do thedog
command.@jks,
Larry
@Powernumpty , thanks for the suggestion. I did that then the update_fix and it took off.
Looks like its going to be v1.465, Happy Happy Happy.
73, Larry WB8LBZ
El Paso, TX
73 Stu
When I display the admin page, only tabs are displayed.
http://www.jp1odj.com/window.jpg
I cannot enter shell commands.
I don't understand the operation.
Please help me.
(I don't understand English, so I use translation software.)
ご迷惑をおかけしましたことをお詫び申し上げます。 これらの指示に従ってください。 まず、管理ページが表示されたら、ブラウザメニューからブラウザの「コンソール」ウィンドウを開きます。 以下に示すFirefoxの例。 管理ページにアクセスできないため、以下にKiwiユーザー接続を示します。 ただし、この手順は管理ページでのみ機能します。
次に、コンソールウィンドウの下部で、緑色の矢印が指す場所に次のように入力します。 ext_send( 'SET force_check = 1 force_build = 1')これにより、現在のバージョンへのソフトウェアの再構築が開始されます。 30〜60分かかります。
Thank you for your prompt reply.
After entering ext_send('SET force_check=1 force_build=1'), the next screen is displayed.
After that, neither KiwiSDR nor Firefox can be seen moving.
Should I turn the power off and on after about 60 minutes?
From the update _fix thread -
"When it finishes restart using the restart button on the admin control tab. Or if connected via ssh use the
ku
command."Stu
