Can’t access admin. [fixed]
My kiwi is working fine on my network, typing in the usual local address and all is fine. If I “/admin” it won’t allow access to the page giving info:
No admin password set. Can only connect from the same local network client.
Nothing has changed via my network. I also can’t access the SDR externally
can somebody help please.
Thanks.
"No admin password set" Change that
Thanks,
post edited.
I would add password if I could access Admin.
Ta
Is this still an issue? I was able to figure out which public Kiwi this was by reverse engineering your forum registration (if public, ALWAYS give your Kiwi details to save me time).
I had no problems connecting as a user. It seems to have been recently updated and restarted.
Were you talking about admin access from your local network? There is a known problem when using the browser forward/back buttons to switch between user and admin pages. Sometime you get a spurious admin page password prompt when there should be none. A simple refresh will fix the problem. It is not known why this happens.
Ah, do you have access to the router interface from outside the network or access to another device on the network?
The blocking of external "Admin" access is a security feature enabled until a password is set so what you are looking to do is get round security.
I’ve just reset the Kiwi and everything appears to be fine. I will set up a password now.
Thanks.
In answer to the Admin access. Yes, from the local network I run the Kiwi on, that’s why I was confused.
I can now access Admin and externally connect to my Kiwi.
Thanks
