wifi connection and local time
                    since I installed the connection by wifi, kiwi can no longer find the time and does not work correctly no audio and very high latency if I reconnect the wired connection everything is back in order always using the URL of wifi connection.
Wed Aug 26 10:19:42 00:44:00.721 ........ [00] PWD admin config pwd set TRUE, auto-login FALSE
Wed Aug 26 10:20:29 00:44:47.799 ........ TIMEZONE: lat/lon from admin public config: (49.220001, 2.210000)
Wed Aug 26 10:20:29 00:44:48.019 ........ TIMEZONE: timezonedb.com curl error
Wed Aug 26 10:21:29 00:45:48.023 ........ TIMEZONE: lat/lon from admin public config: (49.220001, 2.210000)
Wed Aug 26 10:21:30 00:45:48.249 ........ TIMEZONE: timezonedb.com curl error
For sync clock with ntp server manualy you can use ntpdate from SSH:
sudo apt install ntpdate -y
sudo service ntp stop
sudo ntpdate 0.fr.pool.ntp.org
sudo service ntp start
73! Yuri
Thanks for replay, the utc time is correct by GPS only the local time is missing, if I connect the ethernet wired link everything becomes ok again
73' Rene
About screenshot, I seen same result with wire connection when ntp protocol from local network was blocked and BBG could't update time correctly. It's display wrong UTC time and symbol "?" on local time, because curl to timezonedb.com return error. Of course maybe my case only looks like yours...
73! Yuri
I have 2 kiwi and i have the same problem on both, if I put the wired connection all the local time will be ok (camanserville.no-ip.biz:8073)
Just with the wifi dongle if I test Time =
root@kiwisdr:~# timedatectl status
Local time: Thu 2020-08-27 11:05:27 CEST
Universal time: Thu 2020-08-27 09:05:27 UTC
RTC time: Thu 2020-08-27 09:05:27
Time zone: Europe/Paris (CEST, +0200)
NTP enabled: yes
NTP synchronized: yes
RTC in local TZ: no
DST active: yes
Last DST change: DST began at
Sun 2020-03-29 01:59:59 CET
Sun 2020-03-29 03:00:00 CEST
Next DST change: DST ends (the clock jumps one hour backwards) at
Sun 2020-10-25 02:59:59 CEST
Sun 2020-10-25 02:00:00 CET
root@kiwisdr:~#
73' Rene F6bir
curl -s --ipv4 "https://api.timezonedb.com/v2.1/get-time-zone?key=HIHUSGTXYI55&format=json&by=position&lat=49.220001&lng=2.210000"
This request return something when KiwiSDR on the wifi connection or not?
73! Yuri
it works if I reconnect the Ethernet cable
root@kiwisdr:~/Beagle_SDR_GPS# curl -s --ipv4 "https://api.timezonedb.com/v2.1/get-time-zone?key=HIHUSGTXYI55&format=json&by=position&lat=49.220001&lng=2.210000"
root@kiwisdr:~# cdp
{"status":"OK","message":"","countryCode":"FR","countryName":"France","zoneName":"Europe\/Paris","abbreviation":"CEST","gmtOffset":7200,"dst":"1","zoneStart":1585443600,"zoneEnd":1603587600,"nextAbbreviation":"CET","timestamp":1598607605,"formatted":"2020-08-28 09:40:05"}
Have a nice day
For example does it separate the wireless clients from each other, or wireless from LAN clients?
Thank you for your relevance
73 'F6bir Rene
Perhaps there are settings like "Security", "Client Isolation" or even "Guest network" that last one is normally more of a problem if the user is trying access services.
I could be completely wrong on this but I'd like to know those settings are off, and ideally the router is turned off, then ensure the Kiwi is NOT connected by cable and the router turned back on.
Sometimes if the wireless is blocking traffic, going from Ethernet to Wifi can retain some network setting and give the impression it is working but not fully.
A cold-boot to wireless only should give us a clearer idea of the condition of WiFi as the Kiwi sees it.
73 Stu
What happens if you do: versus
ping kiwisdr.comI'll bet this is a problem with DNS not working with WiFi for some reason (router configuration problem?)
Concerning the box and the router, I have already checked or even modified certain parameters without success.
I realized the manip proposed by JKS here are the results for the two kiwis and on a Raspi (and all other) connected to the same wifi network without any wired connection at the same place for the three devices. It seems to be a specific problem at BBB
Admin / console access on the 2 kiwis are rene7890 for a while.
camanserville.no-ip.biz:8073 or 8074
and ssh pi@camanserville.no-ip.biz same PW for the Raspi/OpenWebRX
73 'Rene F6BIR
root@192.168.1.26's password:
Last login: Sat Aug 29 07:38:37 2020 from 192.168.1.73
root@kiwisdr:~# ping kiwisdr.com
ping: unknown host kiwisdr.com
root@kiwisdr:~# ping 50.116.2.70
connect: Network is unreachable
root@kiwisdr:~#
root@192.168.1.27's password:
Last login: Wed Aug 26 11:21:56 2020 from 192.168.1.72
root@kiwisdr:~#
pi@openwebrx:~ $ ping kiwisdr.com
PING kiwisdr.com (50.116.2.70) 56(84) bytes of data.
64 bytes from li420-70.members.linode.com (50.116.2.70): icmp_seq=1 ttl=51 time=153 ms
64 bytes from li420-70.members.linode.com (50.116.2.70): icmp_seq=2 ttl=51 time=159 ms
64 bytes from li420-70.members.linode.com (50.116.2.70): icmp_seq=3 ttl=51 time=152 ms
^C
The default gateway could be missing or wrong defined.
Can you show the output of "ifconfig" and "route"?
For the first one
Last login: Thu Aug 27 05:15:34 2020 from 192.168.1.86
root@kiwisdr:~# ifconfig
eth0 Link encap:Ethernet HWaddr 78:04:73:83:2a:c0
UP BROADCAST MULTICAST DYNAMIC MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0
Interrupt:175
eth0:avahi Link encap:Ethernet HWaddr 78:04:73:83:2a:c0
inet addr:169.254.7.220 Bcast:169.254.255.255 Mask:255.255.0.0
Interrupt:175
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:99916 errors:0 dropped:0 overruns:0 frame:0
TX packets:99916 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:7679368 (7.3 MiB) TX bytes:7679368 (7.3 MiB)
wlan0 Link encap:Ethernet HWaddr f4:f2:6d:09:6f:a0
inet addr:192.168.1.27 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::f6f2:6dff:fe09:6fa0/64 Scope:Link
UP BROADCAST RUNNING MULTICAST DYNAMIC MTU:1500 Metric:1
RX packets:11745 errors:0 dropped:1295 overruns:0 frame:0
TX packets:447 errors:0 dropped:9 overruns:0 carrier:0
RX bytes:4407703 (4.2 MiB) TX bytes:50767 (49.5 KiB)
root@kiwisdr:~# route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default * 0.0.0.0 U 1002 0 0 eth0
link-local * 255.255.0.0 U 0 0 0 eth0
link-local * 255.255.0.0 U 1000 0 0 wlan0
192.168.1.0 * 255.255.255.0 U 0 0 0 wlan0
root@kiwisdr:~#
for the second one:
Last login: Sat Aug 29 07:45:44 2020 from 192.168.1.73
eth0 Link encap:Ethernet HWaddr 40:bd:32:e9:46:08
RX bytes:0 (0.0
Interrupt:175
RX packets:97491 errors:0 dropped:0 overruns:0 frame:0
TX packets:97491 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:7500908 (7.1 MiB) TX bytes:7500908 (7.1 MiB)
wlan0 Link encap:Ethernet HWaddr 60:e3:27:17:15:c3
inet addr:192.168.1.26 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::62e3:27ff:fe17:15c3/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:162197 errors:0 dropped:18345 overruns:0 frame:0
TX packets:157407 errors:0 dropped:28 overruns:0 carrier:0
RX bytes:20635459 (19.6 MiB) TX bytes:137571252 (131.1 MiB)
root@kiwisdr:~#
And for the Pi on the same wifi network:
pi@openwebrx:~ $ ifconfig
eth0: flags=4099 mtu 1500
ether b8:27:eb:94:fe:c1 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73 mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1000 (Local Loopback)
RX packets 24213 bytes 1192572564 (1.1 GiB)
TX packets 24213 bytes 1192572564 (1.1 GiB)
wlan0: flags=4163 mtu 1500
inet 192.168.1.41 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::ec90:d14f:956c:e582 prefixlen 64 scopeid 0x20
ether b8:27:eb:c1:ab:94 txqueuelen 1000 (Ethernet)
RX packets 5886 bytes 652420 (637.1 KiB)
TX packets 5073 bytes 2884241 (2.7 MiB)
pi@openwebrx:~ $ route
default box 0.0.0.0 UG 303 0 0 wlan0
192.168.1.0 0.0.0.0 255.255.255.0 U 303 0 0 wlan0
pi@openwebrx:~ $
The second kiwi doesn't have a default gateway at all.
So the systems don't know how to reach the internet.
There seems to be something going wrong when setting up the ip configuration of the wlan0 interfaces. I don't remember how it is done in the kiwis "stock" configuration, since I modified mine quite a while back.
Is it via /etc/network/interfaces ? I don't remember.
Amusingly one of the Kiwis decided that the wireless card would work again, but would only talk to the network on the ethernet connection. This meant that the Kiwi thought the ethernet was not the LAN, and required the use of passwords for local admin access etc. Went in with connmanctl and disabled wifi, problem resolved.
Thank you for your help
If the configuration is done using /etc/network/interfaces, then you can add "gateway 192.168.1.1" (assuming that is the ip-address of your router) to the wlan0 section.
Or for a temporary solution you could do "route add default gw 192.168.1.1 wlan0" in the terminal.
thank you
73! Yuri
Tu 73 Rene
Hope you can configure routes for wlan0 interface.
73! Yuri
TU
All seems ok now the UTC time is correct I am testing WSPR for a while to check if UTC time is updated normaly. Local time is always faulty indicated as" ?"
See camanserville.no-ip.biz: 8073 or 8074 same default on both kiwi and tell me if everything looks correct to you
Thank you for your help which allowed me to find my mistake
73'
Last login: Sun Aug 30 10:43:13 2020 from 192.168.1.73
root@kiwisdr:~# ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=117 time=12.7 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=117 time=14.1 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=117 time=12.6 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=117 time=11.6 ms
64 bytes from 8.8.8.8: icmp_seq=5 ttl=117 time=13.0 ms
64 bytes from 8.8.8.8: icmp_seq=6 ttl=117 time=12.5 ms
64 bytes from 8.8.8.8: icmp_seq=7 ttl=117 time=13.8 ms
64 bytes from 8.8.8.8: icmp_seq=8 ttl=117 time=16.1 ms
^X64 bytes from 8.8.8.8: icmp_seq=9 ttl=117 time=12.6 ms
64 bytes from 8.8.8.8: icmp_seq=10 ttl=117 time=15.1 ms
^C
--- 8.8.8.8 ping statistics ---
10 packets transmitted, 10 received, 0% packet loss, time 9013ms
rtt min/avg/max/mdev = 11.645/13.467/16.145/1.295 ms
root@kiwisdr:~#
nameserver 8.8.8.8.
After that you can resolve DNS names from BBB, but it's work temporary, for first reboot...
I don't know how you configure IP on wifi interface, but if you use connmanctl you need to use something like:
connmanctl config <<your_wifi_service>> --nameservers 8.8.8.8 8.8.4.4
73! Yuri
Mon Aug 31 07:59:57 21:50:45.537 0... [01] PWD admin config pwd set TRUE, auto-login FALSE
Mon Aug 31 08:00:28 21:51:17.020 0... TIMEZONE: lat/lon from admin public config: (49.224380, 2.210537)
Mon Aug 31 08:00:28 21:51:17.236 0... TIMEZONE: timezonedb.com curl error
Mon Aug 31 08:01:28 21:52:17.239 0... TIMEZONE: lat/lon from admin public config: (49.224380, 2.210537)
Mon Aug 31 08:01:29 21:52:17.468 0... TIMEZONE: timezonedb.com curl error
Mon Aug 31 08:02:29 21:53:17.471 0... TIMEZONE: lat/lon from admin public config: (49.224380, 2.210537)
Mon Aug 31 08:02:29 21:53:17.652 0... TIMEZONE: timezonedb.com curl error
Mon Aug 31 08:03:29 21:54:17.656 0... TIMEZONE: lat/lon from admin public config: (49.224380, 2.210537)
Mon Aug 31 08:03:29 21:54:17.871 0... TIMEZONE: timezonedb.com curl error
UTC time seems ok, wspr running well since 12hours with wsprnet reporting (f6bir/m)
connmanctl enable wifi return "time out" I configured Wifi manual using nano /etc/network/interfaces
I added "nameserver 8.8.8.8" in resolv.conf file.
I will try again soon
have a nice week
73' Rene
I think the manual system conflicts with connman and visa-versa.
Perhaps see if you can exclude connman on that interface?
https://askubuntu.com/questions/798346/does-anybody-know-how-to-disable-connman
Thank you for your patience
Mon Aug 31 12:03:42 03:47:24.742 0... TIMEZONE: timezonedb.com curl error
Mon Aug 31 12:04:42 03:48:24.750 0... TIMEZONE: lat/lon from admin public config: (49.224380, 2.210537)
Mon Aug 31 12:04:43 03:48:24.931 0... TIMEZONE: timezonedb.com curl error
Mon Aug 31 12:05:43 03:49:24.934 0... TIMEZONE: lat/lon from admin public config: (49.224380, 2.210537)
Mon Aug 31 12:05:44 03:49:26.126 0... TIMEZONE: from timezonedb.com for (49.224380, 2.210537): utc_offset=7200/2.0 dst_offset=0/0.0
Mon Aug 31 12:05:44 03:49:26.129 0... TIMEZONE: "CEST", "Europe\/Paris"
