Strange CPU usage and cannot log on
edited August 2017 in Problems and Issues
Hello all,
I am have some strange issue with my kiwisdr - the site is remote but all my actions are performed on a windows pc  sitting at the same remote location  (access via teamview.)
I am getting this strange Beagle CPU 109741 and user 102936%
Picture here
I am also having trouble logging onto the admin page -  have to reload many times
I can SSH in all ok -
I have done a reboot and complete power down and back remotely.
I am all out of ideas?
Its like something in the files system is damaged
THanks Matt S
https://forum.kiwisdr.com/uploads/Uploader/fa/741a49b184e032219c101816f80f1f.jpg
https://forum.kiwisdr.com/uploads/Uploader/29/bddfb34d71db89a398725db77c492d.jpg
    edited July 2017
    I've seen the CPU numbers be wrong for the first sample interval (they get updated every 10 seconds). But they should be okay after that. They are derived directly from /proc/stat. If you can ssh into the Beagle what happens when you type "cat /proc/stat"?
    root@kiwi:~/Beagle_SDR_GPS# cat /proc/stat
    cpu  16620630 0 16514304 133281519 114374 0 45810 0 0 0
    cpu0 16620630 0 16514304 133281519 114374 0 45810 0 0 0
    intr 149224146 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 105231723 0 0 1 2462977 0 154994 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 190 1430 1148999 13 11410222 0 0 0 0 0 0 0 0 0 0 0 0 16170103 12643493 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0
    ctxt 158792904
    btime 1499810846
    processes 3223827
    procs_running 2
    procs_blocked 0
    softirq 127612332 1 96488644 333769 24780166 0 0 6009752 0 0 0
    Not being able to load the admin page is strange. If you can bring up the javascript console window in the browser I'd like to know what errors it might be showing. Once you can get in you might look at the "log" tab of the admin page and see if there are any error-looking messages. You can do something similar by logging into the Beagle with ssh and typing "cdp" then "ms" to look at the log that way.
    You could just re-flash the Beagle from the sd card. But then you lose all your configuration settings which is unfortunate.
    Was it working okay prior to this?
  • HI thanks for the feedback
    Is it possible for me to reflash the card using the beagle itself without changing the SD card  (its a remote site)
    THanks.
    Here is some info
     cat /proc/stat
    cpu  4978176 0 1328413 1720025 496 0 16202 0 0 0
    cpu0 4978176 0 1328413 1720025 496 0 16202 0 0 0
    intr 71106773 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 16221202 0 0 1 51739904 0 66 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 194 1442 104928 13 86822 0 0 0 0 0 0 0 0 0 0 0 0 1686105 1266093 0 0 0 0 0 0 0 0 0 0 1 0 2 0 0 0 0 0 0 0 0
    ctxt 195667581
    btime 1501476356
    processes 6281
    procs_running 1
    procs_blocked 0
    softirq 69998148 1 16017253 16276 2269452 0 0 51695166 0 0 0
    I cannot logon to the admin or  user web pages - error message below
    This site can’t be reached
    10.1.1.16 refused to connect.
    Try:
    ERR_CONNECTION_REFUSED
  • Hi Matt,
    /proc/stat looks okay.
    Could you email me at support@kiwisdr.com ?
    If possible I'd like to Teamview into the PC and then ssh into the Beagle and look around a bit. It's possible this is some problem like a full filesystem or the server restarting over and over again in a loop for some reason (we've seen both in the past).
    There is no process I know of to re-flash the filesystem over the network from a program running on the Beagle booted from the same filesystem (it would be nice though). I've always had to re-flash after booting from an inserted sd card, which as you point out is a big pain for Kiwis locate at remote sites.
