Webbrowser with audio output selector
Decoding from my and other KiwiSDR receivers makes me run into the problem that Chrome outputs the signal to the "windows default device". So I have to set the default device to a virtual cable, listen to the device = on and I can decode a lot of modes.
However, if I use DSD with my local SDR, DSD also uses the default device, as output, so it starts stuttering because it gets its audio output back on it's own input. I have to "listen to the device = off" to solve this, so I have to switch between settings when I switch programs.
Does anyone know of a browser which works with KiwiSDR and where I can set the output device for audio ?
Thanks,
Ben
P.S: Could it be possible to widen the SSB bandwidth for some DRM testing ?
