v1.673
From the CHANGE_LOG file
v1.672,673 April 23, 2024
Integrated antenna switch fixes/improvements:
API changes for antenna switch backend scripts. If you have a private script please review
the scripts in Beagle_SDR_GPS/pkgs/ant_switch/backends to see the changes.
Lower switching latency for MS-SnA-WEB switches as a result of API changes.
Added support for LZ2RR MS-S5A-WEB and MS-S6A-WEB switches.
New setting "disable" for switch device.
Fixed problems with default antenna selection when no users connected.
Backend scripts can indicate that antenna mixing is not supported (e.g. MS-SnA-WEB switches)
Removed debugging prints. No longer appear in log.
