KiwiSDR failed after software update?
One of my KiwiSDRs seems to have stopped working after a software update about 10 days ago (yes, I just noticed it), the other four are fine.
I've tried ssh'ing in and doing a manual build with ./up several times, I don't see any errors, but I still can't connect via a browser, either to the normal KiwiSDR page or the admin page.
One thing I did notice, running ps -aux only shows the kiwid service running:
root 6865 97.3 5.9 135364 29760 ? RL 12:41 15:55 /usr/local/bin/kiwid -use_spidev 1 -bg -v 1.665
While on a working KiwiSDR I also see kiwi.leds running, not sure if this is a clue or not:
root 32445 84.5 23.2 248004 117340 ? DL Mar11 24542:28 /usr/local/bin/kiwid -use_spidev 1 -bg -v 1.665
root 32462 0.0 8.4 169604 42608 ? S Mar11 18:24 kiwi.leds -use_spidev 1 -bg -v 1.665
Any ideas? I haven't tried going back to an SD card install yet, still hoping I can recover without losing all the setup info.
Well this was interesting... I restarted it several times from within the ssh shell connection, no luck. Then I tried shutting it down, cycling power, and it came up!
Something I will remember (or try to) for the next time this happens. 😀
