That last idea is fascinating. Putting anything around a 3/8" guy wire with 2000 pounds of tension on it isn't viable but I believe I have the pickup from the anchor solved and adding another one would be doable. The third guy anchor would be a challenged to get a feedline back from. Food for thought in any case.
Your guy is actually a bit thinner than I expected.
The cores I suggested will accept 1" diameter, and they split in half and clip back together. So you can easily clip one over a guy, and let it rest against a turnbuckle or whatever, to stop it slipping down.
It shouldn't interfere with the operation of the guy, or add any extra physical load, but it was only a suggestion.
The small tower (22m) used at my Wessex websdr site is free-standing with no guys. So I had to add a sloping wire, connected to the top of the mast, and connected to a balun at the bottom, with a ground return wire going back to the tower base. If it had guys I would have preferred to use the method I've suggested.
Hi Bob,
