strange behavior with 2 kiwi's
Hello,
I have got kiwi's on one location and an identical configuration except the name, ip address and the password. In the router I forwarded port 8073 to kiwi01 and port 8074 to kiwi02. Both the kiwi's are accessible from the internet.
When I search for the kiwi's on http://rx.linkfanel.net/ only one of the kiwi's is located on the spot I configured in the Webpage and Public menu. The other kiwi is floating randomly over the map in a circle between 5 to 20 kilometers from my location.
After a reset of kiwi02 it appears on the real location of the map and the other kiwi starts floating. Somehow it seems they share the same identity.
I didn't use the clone function for the second kiwi.
Is there a parameter which i misconfigured?
regards,
vcc033
I don't run that map site, but the code seems to dither the position of overlapping map markers so they don't obscure each other. The map code is here: https://github.com/priyom/dyatlov And this comment is contained in the file
dyatlov.js// Shift coordinates to ensure marker is sufficiently distinct
// from others to be distinctly seen and used
So you haven't misconfigured anything. That's just the way it is.
