Reverse proxy
In the old days, reverse proxy was working fine with my Kiwi.
Now, I can not get it to work in my browser.
The admin page says that the proxy is not working per the port test function.
Is it necessary to re-register in the post sdr.hu days?
Chuck
Chuck
xxx.proxy.kiwisdr.com
)But then I also see in the server logs where you used the "Check port open" button while the host name was set to "huttonkiwi" and the check failed using that host name. So that's probably the source of the problem. To fix it follow the steps in my last post.
Thanks for the answers. It is up and running and I like that.
Chuck
Hello, I would like to operate my Offgrid Kiwi near the Arctic Circle on a 4G router. I wanted to set up the proxy, now I would need a user key to enter, where can I get it from
Hi. I just responded to your email a few minutes ago (it's 6:30 AM here in New Zealand, lol). I sent you an API key to enter in the proxy configuration panel. Follow the setup instructions linked on that page and let us know if it doesn't work for you.
Hello, thank you very much, I just saw the email. Yes great, everything is done and it works, thank you very much for your help. best regards Manuel 😄👍
