Password protected channels and 8 channel mode
Looking for some clarification on setting up password protected channels on a receiver set up in 8 channel mode - 2 waterfall and 6 audio only channels. If I set up 2 of the channels as password protected will those be the 2 waterfall channels?
I would like the two waterfall channels to be password protected and the audio only to be open to the public. I didn't see any documentation stating it would work that way in that mode. Can anyone clarify this for me?
Thank you.
- Rob
Thank you.
- Rob
The final two channels will not always be channels #6 and #7 (of 0-7) because connections will established and closed randomly. So the final two as the occupancy is filling up could be any of the channels. A special check would have to be made in 8-channel mode to force the first two channels (waterfall channels) to be the last ones assigned (but only for connections subject to the occupancy check, e.g.not local connections).
Thanks again for taking the time to confirm and respond to this.
