Whats wrong with my Kiwi?
Hi could someone have a look at my Kiwi and see if you can see what's wrong? Since the weekend the display looks different - quite grainy - and the audio not so good.
(Relative newbie here so help is appreciated).
Thanks!
http://ei2hh.com/sdr
Thanks!
The change you see in the waterfall is probably due to the changes in the waterfall: http://forum.kiwisdr.com/discussion/2112/v1-403-colormap-improvements-multiple-drm-schedule-databases#latest
Adjust the waterfall settings and everything looks OK. Change the second popup menu in the waterfall tab from Auto to Man (manual) to go back to the "old way".
Is it possible to add in the Config tab the settings for WF ceil / floor in Aperture Auto mode to start with 0dB values? The waterfall then looks much better than the default ceil + 5dB / floor -10dB
greetings
Artur
