New Beaglebone - KiwiSDR not visible after reboot (Solved)
Until some time ago, my "ArcticSDR" was working ok. I then performed a Beagle reboot, after which the Kiwi never came online again. I cut power twice, with no results. I had a spare beaglebone after a failure a year ago with the same Kiwi, so I installed it and ran the original SD card. When all LEDs dark, I removed the SD card and attached power again. After some time, the LEDs show off a double-blink on the "edge" side of the board, and it seems to be stuck in that position. Not visible with the auto-discovery scanner, my.kiwisdr.com or via ping. Power is good, 5.2V. I vaguely remember from earlier discussions that a double blink is not a good sign. The other Kiwi I have connected have no problems with reboot or power.
Is there a Kiwi board present in this situation of continuous double-blink? The Kiwi software won't start and hence won't show its pattern if there is no Kiwi board installed. So If there is a Kiwi board, and you're getting nothing but double-blink, then something is not right. It would be very helpful at this point to ssh/PuTTY in as root, "cdp", then "ms" and see what the Kiwi software startup has to say.
Remember that if you re-flash with the original sd card, which restores the Kiwi software to version v1.2 (as opposed to a backup sd card which might be a much more recent version), it will take an hour before the Kiwi is responsive to user connections. A Ping should work during that hour long update process. The others as well although I can't guarantee it without trying it.
